Question about Mitsubishi WD52527 52" Projection HDTV
Green light flashes and than goes off for 30 seconds.
I also have the green light flashing for about 30 seconds and than goes off. i tried to count the times the green flashes but i lost count well over 120 times. could you please tell me what it could be? thank you
  • addgray Aug 07, 2008
    My green light flashes like it is resetting or just plugged in. After flshing stops, unable to power on with remote or set's power button. After a couple of minutes it starts flashing again. Only way to stop is to unplug AC cord. Tried everything manual said and verified 120V at wall outlet.
  • Anonymous Mar 15, 2009
    "Green light flashes and than goes off for 30 seconds."
  • 4,234 Answers
If your TV is a Mitsubishi, there is no count actually. You are the victim of the famous "green flashing light" problem. This is resolved by replacing a number of bad capacitors on the "D" board I believe. If you can solder, you may be able to resolve this. Be aware however that some of these caps may be surface mounted which is a more intricate task.
Let me know if you wish to attempt this and I'll provide more details.
Dan
Posted on Jul 30, 2008
The green light on my scooter flashes for mintues then stays green like it should do, any advice
The green led flash codes are in your Pride owners manuals, from
1 flash up to 10 flashes, then the pattern repeats or it goes to a steady green. You have to count the flashes from the beginning to determine what the problem is. It's not very convenient, but that is
all they have for owners to troubleshoot.
Feb 16, 2015 | Health & Beauty
Blinking green light
It is likely that the power supply is failing. It tries to start and powers up briefly then shuts down.
Oct 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    R7184b just got oil reset wont reset tried main furnace reset same thing green light still keeps flashing any ideas????
    if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
    Jan 17, 2010 | Heating & Cooling
    No picture, status light flashes yellow
    display comes on works 15 seconds no power just leds green
    Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
    Hard drive unit has a green flashing light but won't turn on
    Try reseatting / swapping the memory.
    How long ago did you purchase this desktop?
    Jun 18, 2009 | Sony VAIO VGC-RB43 PC Desktop
    SONY GRAND WEGA
    I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
    May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
    Won't turn on, only flashes red light
    Probably the filter is blocked. Unplug the power lead at the back and leave for about 30 seconds. Plug back in and it should work. The first opportunity you get, buy some compressed air and give it a good clean.
    May 07, 2007 | Epson PowerLite 50c Multimedia Projector
    Mitsubishi WD52527 52" Projection HDTV Logo
    606 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
