SOURCE: My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
SOURCE: have upgraded firmware to latest today....still
Try to find how to become you DVD multi region. It uses region recognition function and it is problem for you.
SOURCE: my aquos bluray player has stopped playing my blu
Sound like the firmware needs to be updated for the newer encryption schemes had the same problem with my bd-hp21u with a couple of new bd discs. You will need a 1gb or smaller USB drive to put the updated firmware on which Sharp doesen't tell you. The rest is in the manual or available from sharp support.
