Question about Philips Magnavox 20MT133S 20" TV
20MT133S picture too wide for tube
My tv's picture seems to run past the tube by about 1/2". I don't see any adjustments on the outside to reduce the picture size. Any sugestions?
There is a section in menu but i can't think of which one it is at the moment. I would suggest playing with your menu and you will find it.
Posted on Aug 14, 2008
Picture tube
No question is really indicated here, if the picture tube in this set turns out to be bad buy a new set.
Dec 05, 2012 | Philips Magnavox 20MT133S 20" TV
PICTURE TO BIG AT THE SCREEN.CAN NOT SEE THE PICTERS MARGIN AT THE SCREEN.HOW TO ADJUST(REDUCING PICTURE SIZE ON SCREEN)?
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2)
Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
Aug 14, 2010 | Televison & Video
Sony 42inch tv picture has reduced itself to size of regulaur tv instead of wide screen. How can this be adjusted ?
There should a selection for the size picture your viewing. There is most likely a zoom selection as well.
Dec 28, 2009 | Televison & Video
Bp30185 wont full run wide open
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 22, 2009 | Homelite Garden
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
Poor picture, raster & sounds ok
If the picture is fuzzy (out of focus) it may have a focus adjustment on the flyback transformer. Possibly an adjustment available from the outside, through the back. Look for any markings on the plastic housing indicating Focus, Brightness etc.. You can use a small screwdriver through the labeled holes in the case to make adjustments.
If the picture is crisp, but faint or the colors seem washed out it may be the tube is at it's end of life or needs to be rejuvenated. TV shops can rejuvenate tubes but it's not cheap.
Mar 11, 2008 | Konka K2386U 23" TV
Bad picture. in wide
sir kindly adjust its screen focus of your tv,,, thankss and hope too help you,,,gud luck
Feb 25, 2008 | Televison & Video
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
Philips Magnavox 20MT133S 20" TV Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
