Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he3
Water starts filling and then leaks out of the drawer where bleach/detergent go. I already cleaned filter from h f error code?
    Genius:
  • 1,028 Answers
Ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Posted on Jul 30, 2008
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
Kenmore Elite HE4 won't start
Top 10 front-load washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisy,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nesessary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Over-sudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE5 Dryer beeps while running
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 14, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Water in the bleach dispenser
The bleach dispenser is a syphon system. When you put in the bleach , it fills the reservoir to a point just below the syphon point. Your bleach tray has a tube attached to it, with a loose cap around the tube that causes the bleach to be delivered to the washload when the water is added. Remove the cap over the tube in your bleach tray. You'll also note a similar arrangement for your softener dispenser. Clean both caps and tubes. Make sure that the caps fit properly back down over the tubes. The syphoning effect will work only up to the point that the circuit is broken by air. If your cap sits up too high, the syphon effect is broken early, leaving residue (water) in the dispenser.
Best regards, --W/D--
Aug 09, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
322 people viewed this question
Sal De
fordexpert
Robert Rankin
