Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
No signal input, please check video signal
When i turn on my computer my monitor displayr a box tha says "no signal input please check video sigal" then saves power and goes black and it be like 8 or 9 days betwen before i can see my windows boot up s7700n slimline with windows vista
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: my hp slimline 3600f monitor
You should try your PC with another monitor to make sure it is not the video card problem.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 08, 2010
joecoolvette
  • 5660 Answers
SOURCE: when i turn on my computer all it tells me is sva
No Signal.
No signal coming from the computer.
The monitor is working, but there isn't any video signal coming from the computer.
1.Could be a bad video cable. The one from the monitor to the computer.
Do you have another computer available to test this monitor on? Use the video cable attached to it now.
Works?
You have a computer problem.
Doesn't work?
Use the video cable on the computer you're doing a test with.
Works?
You have a bad video cable.
Computer problem.
Does your computer have a graphics card, or is it Integrated Graphics that the monitor is plugged into?
(Integrated Graphics is also referred to as 'Onboard' graphics. ON the motherBoard)
With Integrated Graphics your monitor will be plugged into the I/O area on the back of the computer.
I/O = Input/Output
This area, is where the rectangular metal shield on the back of the computer is located. A mouse and keyboard are usually connected in this area.
Example of an I/O Shield,
http://ep.yimg.com/ca/I/directron_2079_111707086
A graphics card is a separate hardware component that is plugged into an expansion slot, and you will see it towards the bottom of the computer case. There are slots in the metal frame of the computer case, and you will see the outside edge of the graphics card located in one of these slots.
Example of a basic graphics card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5271084&Sku=G458-9603
It could be a problem with the Integrated Graphics, (GPU soldered to motherboard), or an issue with the graphics card, if used.
The main problem I see when repairing are one of three issues, or a combination of two or more issues.
1.The inside of the computer is dirty, and the power supply.
2.The power supply is bad.
3.Electrolytic Capacitors have failed, or are failing on the motherboard.
1a.If the inside of the computer is dirty, so is the inside of the power supply. The power supply's fan draws air through the computer.
Dust/Dirt/Hair, and other foreign objects, are drawn in with the air from the cooling fan/s, and the power supply fan.
No matter how good a person is as a housekeeper, this foreign material is drawn in. It requires a regular cleaning of the inside of the computer, as well as the power supply.
The computer is turned off, and unplugged from power. Computer case open. A can of compressed air is then used to clean the computer. (Plastic straw attached. Do Not make the small processor fan spin too fast. It is only designed to spin so fast. Spinning it faster than it is designed for, can lead to premature failure of the fan's bearings)
2a.Power supply failure. This is a multifaceted problem.
When foreign material clogs the cooling components inside the computer, (Fan/s, and processor heatsink), plus the power supply, (Fan, and heatsinks inside), the power supply has to put out more power.
Heat = Wasted Energy.
The more heat due to cooling capacity drop, the more power is required. The power supply can only keep up so long, and components inside eventually fail.
Generally it's Electrolytic Capacitors as they are the weakest link. Electrolytic paste inside the capacitor develops a gas, and breaks the seal stature of the capacitor. This leads to Electrolytic paste oozing out, and capacitor failure to follow.
A power supply with failing, or failed capacitors has a weak voltage rail, or more than one voltage rail.
There are three voltages produced by a personal computer power supply.
A.3.3 Volts
B.5 Volts
C.12 Volts
With a bad power rail the power supply has enough power to light lights, and spin fans, (Usually), but not enough power to turn the processor on.
1.ALL the lights require less than 1 Watt.
2.EACH fan requires 2 to 3 Watts.
3.A typical processor requires 55 to 125 Watts. Depends on what processor it is.
(You may even hear the harddrive spinning. Enough power to make the harddrive motor turn, but with no processor, there is nothing to make the Operating System on the harddrive work. Operating System example: Windows XP)
3a.Bad Electrolytic Capacitors on the motherboard.
As mentioned, Electrolytic Capacitors have Electrolytic paste inside. The paste develops a gas, (Hydrogen Gas), and pushes against a rubber seal on the bottom of the capacitor. It can also push against the top of the capacitor, and break the capacitor metal case open.
(Usually there is an X or lK on top of the capacitor. This shape is stamped into the thin metal on top. It spreads open when there is too much pressure, alleviating the pressure that has built up. Paste oozes out of here also)
Electrolytic Capacitors that surround the Processor are Voltage Regulators. The Processor must have a clean, steady, supply of voltage. The Processor has a very small tolerance range.
Too little it doesn't turn on. Too much, and it won't stay on.
This details out the visual signs of Electrolytic Capacitor failure,
http://www.capacitorlab.com/visible-failures/index.htm
Electrolytic Capacitors do not always show visible signs of failure. The paste can dry up inside, and no external failure is present.
If you see capacitor failure on the motherboard, then you automatically know what is wrong.
If you do not see failure of capacitors, then you may want to try using a known, good, power supply for a test.
Would appreciate 'hearing' what the outcome is.
Posted on Nov 20, 2009
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Monotor no input sigal
check out the monitor cables if they are too old change them
Aug 12, 2012 | Dell Dimension E521 PC Desktop
Everytime i start up computer a sigal appears saying "no video input"
I'm assuming after a few minutes, it does get a signal from your computer and all works? It does take about 30s +/- 90s for a computer to generate an output video signal so if your monitor comes on first, before the computer can send a video signal, then you'll see that message. You should see the same message if you shut down your PC and leave the monitor on.
Aug 15, 2011 | Philips 170C4FS 17" LCD Monitor
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
My monitor keeps giving me a no signal message after i turn on my computer
  1. make sure that the video cable is properly connected between the monitor and computer
  2. change the video cable
  3. do a monitor selftest
  • turn off the monitor
  • disconnect it from the power outlet
  • disconnect it from the computer
  • turn on the monitor without the video cable
if you see the monitor information (a box with RGB white colors, the monitor is working)
  • problem might be the cable, video input port of the monitor or the video output port of the computer
Apr 10, 2010 | Acer AL1916W 19" LCD Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
COMPUTER WON'T BOOT UP
The possible reason why there's no signal on the mobo are, first of all it can be a problem with the video card and since you already tried replacing the video card and still no sigal so it means not the video card problem, you can also try to connect a different monitor if possible to check if its not a problem with the monitor and also a bad motherboard will cause this since the video card is connected to it and so if you already try a different monitor and still the same problem motherboard is the one that is bad....
Nov 02, 2008 | Abit IS7-V Motherboard
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
661 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
