Question about GE Profile Harmony DPGT750EC Electric Dryer
Burnt stove element
Hi there, My 15 year-old GE basic stove has a burnt element. The stove has been discontinued; I looked in Canada and the States. Surely a stove should last longer than this? My husband bought a different element and wants to adapt it. Is this safe?
Many thanks,
  • 868 Answers
It is if its installed like the other one.Generally they are just shaped differently.If the wires are connected safely you should be ok.
Please rate This !!!
Posted on Aug 18, 2008
I have a 30 year old GE electric 2oven range One is up where you would think a microwave would be today. need to replace the element on the lower self cleaning oven. Where can I buy an element?
most electrical wholesale shops carry elements for stoves
the ranges may change but the elements stay fairly constant
if it is possible take the old element with you for comparison
Oct 20, 2015 | GE Kitchen Ranges
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
Mar 10, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
GE profile wall oven transformer part WB20X5063
I have one WB20X5063 in stock in original GE Box unopened.
LISI in Miami 305-653-2284
Apr 16, 2013 | Ovens
Hello, I have an older model GE wall unit oven, single. It is the original unit and is about 40 years old. Tonight, I was cooking dinner and I opened the door. There was a loud buzzing noise and when I...
Hi Leslie,
First of all, the manual isn't going to help you much as they only usually provide information on installation and operation. Also, if the oven is indeed 40 years old, it's probably going to be rather difficult to obtain one.
Considering the age of the oven and your description, it's most likely that the element has simply burnt out rather than any electrical fault. If it's the original element, 40 years is pretty good going!
If you post back with the model number of the oven, I might be able to find the manual and/or a supplier for a new element, but there's no guarantee a replacement is available. It's possible to fit non-standard elements as long as they are of similar size and the same rating, but I would leave that to an engineer as it can require new fixings if the pattern is different.
Nov 17, 2010 | GE Ovens
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Can I use a similar bake element if I can't find the exact match
Yes, I would say you could use a different shaped element.
Apr 28, 2009 | GE Ovens
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
