Question about E-Machines eMachines Desktop PC
Monitor doesn't work
When I turn on my emachine computer the monitor works  (shows windows logo) and the keyboard lights up
 but then the monitor goes to sleep mode... it works fine on my other computer it seems to be a power issue on the rear ports?
    Problem Solver:
  • 6 Answers
Sounds like a bad video adapter. I'm assuming your emachines has an integrated video adapter. Put in a video card (with the power plug pulled out! Touch the bare metal frame of the computer with your hand before inserting the video card into the agp or pci slot Don't touch the motherboard). If you get video, you may or may not need to install drivers after that. XP has a lot of video drivers, but lacks quite a few of them, too.
Posted on Aug 02, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I have a problem with my computer emachines j4501 desktop pc windows vista home premium..after the windows logo the monitor turn blank...but the cpu is still on.... what will i do...
If you can see the windows logo screen both your computer and monitor is working, possible problem could be that the display settings are set to high that your monitor is unable to handle it. Restart computer and keep tapping F8 key. This will take you to the advanced options menu In the list of options here choose enable low resolution mode and hit enter (you can only use your keyboard to choose - use the up / down arrow key) once you enter windows low res mode change it to 800 X 600 and restart the computer Once you are in the right mode now change the display settings accordingly.
Mar 12, 2011 | E-Machines eMachines Desktop PC
Monitor blue light comes on shows emachines logo and color bars then monitor turns off and light turns yellow
your monitor is beleiving it is not receiving any signal from your pc. 1 make sure your cables are secure. 2 make sure your pc is on. 3 borrow a monitor from a freind to see if your pc is sending the signal out, if the borrowewed monitor is showing a picture, hook yours back up. 4 if still not picture your mpcb or video pcb in the monitor is bad.
Oct 28, 2009 | E-Machines eMachines Monitor E15T4
Monitor on emachines computer is black and the on/off light flickers screen will not come on
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Jan 22, 2009 | E-Machines eMachines Monitor E15T4
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
PLEASE HELP ME!!!!!!!!!
Test your power supply for correct voltages. If they are all OK, then your motherboard is toast.
May 13, 2017 | E-Machines eMachines Refurbished EMA...
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
Hi, I have a compaq deskpro that is working fine however, the monitor is having trouble. I took the monitor to the shop and it is fine also. Likewise, I placed a monitor from another computer onto the...
The monitor setting in windows maybe incorrect. When booting up before you get the windows logo start hitting F8 and then choose safe mode. If your monitor works in windows there then check the monitors settings. You may have a driver issue or a settings issue when in normal windows mode.
Jul 07, 2008 | Compaq Computers & Internet
E-Machines eMachines Desktop PC Logo
110 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
