Question about LG DLG5932W Gas Dryer
Runs but no heat
I have a LG dlg5988 gas dryer, it runs but there is no heat. No warranty so I need istructions on repairing this myself.
I WOULD LIKE TO KNOW WHERE THE RESET BOTTOM ON A (LG-GAS 7.0 DRYER)
Posted on Mar 06, 2009
  • 943 Answers
Hi thanks for the question i would first check the thermal fuse it fails often caused by dirt in venting system clean all venting replace thermal fuse thanks the appliance doc
Posted on Sep 27, 2008
I have an LG front load dryer and it has stopped heating. Do you have any suggestions?
Because you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 26, 2011 | LG DLG5988 Gas Dryer
5 women in my family. 4 are swimmers have dried 1500+ loads of towels. now i have to hand start the drum. can i fix this myself; new belt or something?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 23, 2011 | LG DLG5988 Gas Dryer
Unit powers up, check filter light flashes until you turn main control knob to any setting (e.g 'normal'). Press start, unit runs, but no heat. Checked output of vent outside, plenty of cool air is flowing...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | LG DLG5988 Gas Dryer
Gas LG dryer not drying
heatman101
Oct 07, 2010 | LG DLG5988 Gas Dryer
Do not know how to open up machine to look inside
Hello willdano,
Here is a link to the LG Website. Included in this link are all the service details, specs and documents you will need to repair your dryer. http://136.166.4.200/contents/Laundry/DLG5988.htm If you access the service manual, check out page 29 & up for disassembly details on how to access the internal hardware. Hope this helps.
Regards,
Rick
Jan 04, 2009 | LG DLG5988 Gas Dryer
LG gas dryer model # DLG5988B won't heat
turn the gas on or you might have air in the line.
if that dont work check out the ignitor
Dec 09, 2008 | LG DLG5988 Stainless Steel Gas Dryer
LG DLG5932W Gas Dryer Logo
375 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
