Question about Vacuums
How do I replace the belt on my DD Featherlite Vacuum cleaner?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853915
Generic problem for all Vacuums
Posted by kt87saints on July 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name (Royal) and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 30, 2008
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Jul 10, 2014 | Dirt Devil Vacuums
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil featherlite cyclonic belt comes off
What makes the belt come off?
1) Wrong belt. use only genuine DD belt. No generics.
2) Worn out belt. Sometimes a worn belt acts this way. Just because it looks good, does not mean it is good.
3) Belt improperly installed.
4) Brush roll not spinning freely. (replace Brush Roll
5) Brush roll is not installed properly.
6) Machine is worn out where it pivots between the body and the lower nozzle. To check (without a belt installed) see if there is a lot of play forward and backward between the nozzle and the main body. If so, once a new belt is installed and you are pushing and pulling on the handle the motor shaft comes out of alignment.
NOTE: the #6 problem is the rarest and usually is due to an extreme amount of use over years.
Let me know if this helps.
Dec 31, 2012 | Dirt Devil Featherlite Bagless Vacuum...
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
I replaced the belt on my Dirt Devil Featherlite Bagless Vacuum and the brush roller rubs and makes a very loud noise when turned on. I have gone exactly by the manual instructions and made sure the belt...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=561283
Posted by piggytail on May 01, 2008
I replaced the belt on my Dirt Devil Featherlite Bagless Vacuum and the brush roller rubs and makes a very loud noise when turned on. I have gone exactly by the manual instructions and made sure the belt and end caps were on correctly, but the bristles still rub the back and it makes a very loud noise. Without the brush roller in the vacuum, it sounds and runs normal. What could the problem be?
The Royal Dirt Devil Featherlite Bagless Vacuum has just bushings in the ends of the brushroll and not bearings and once the bushings are bad I suggest that you replace the brushroll in the vacuum and put a new belt on the vacuum as well. There is no way to repair the bushing s in order to it to work properly. The suggested belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator to keep them fresh. Suggest looking at a local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Vacuums Logo
73 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
