Question about Asko W6021 Front Load Washer
Asko W6021 Not Working
I have the exact same problem with my Asko as you did (do?). Were you able to fix it? Can you give instructions for taking the front panel off?
Thanks so much for the help!!!
    Sergeant:
  • 351 Answers
Change the carbon brushes
Posted on Aug 27, 2008
Asko w6021 started to fill with water and then shorted out the power any suggestions?
not much help sorry but is possibly the motor shorting, try turn the drum a little before you reconnect and see if it still shorts. I have had an element rupture and therefore be soaked in water and thus causing the short. Sorry I cant help more
Mar 04, 2013 | Asko W6021 Front Load Washer
How do I turn on my washer .. I cant read swedish
Hi dear.Please follow the link below to dowload the quick start guide.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/W6021-_E
I hope that solves your problem.Thanks.
Nov 03, 2010 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Asko w6021 washer leaves clothes damp and often stops mid cycle
I AM NOT MUCH OF A MECHANIC, BUT I DO KNOW THAT IF WATER DOESN'T SPIN OUT OF THE WASHER, IT COULD BE THAT YOUR BELT IS BROKEN OR YOU NEED TO REPLACE THE MOTOR COUPLING.
May 13, 2009 | Asko W6021 Front Load Washer
After a power serge caused by the local power authority we can not open the door to our ASKO W6021 - we have washing locked in the machine and want to take it out before the machine is taken away to be...
prise open the samll square door at the bottom left using the divider in the soap drawer. Once open extract the red loped handle and pull on it ot manually open the door.
Apr 03, 2009 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 front load washer door stuck! If any one can help me please do thanks, Dwayne.
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Oct 24, 2006 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
270 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
