Question about Foxconn 661MX Motherboard
CPU throttles for No Reason!
Hi, I noticed my Pentium 4 CPU throttles down from 3.0GHz to 2.0GHz for no reason, about 95% of the time. I could reboot my computer to restore the CPU clock, but it throttles down again eventually. Needless to say, it's the problem that I've narrowed it down to that's my games to run slower.
I'm using a Foxconn 661MX Plus Motherboard (the one with a SiS 661GX chipset). I'm also using a 550W power supply.
I already ruled overheating out (I put 3 fans already on my Scythe Ninja Mini CPU heatsink and put Arctic Cooling MX-2 thermal pasted). Temps are 50C idle and 60C on load [no matter of ANY external temp]. I also updated EVERYTHING (BIOS included) to the latest drivers. Using Windows XP Pro Service Pack 3. Tried messing around with some of the BIOS settings (such as HyperThreading off) and resetting CMOS sometimes, but no fix.
I've been trying to fix this problem the whole summer. Any help is greatly appreciated. Thanks!
  • thuganomigs Jul 30, 2008
    I forgot: you can rule out adware/spyware, etc. from here, too. This happens even with a fresh install of Windows.
  • thuganomigs Aug 12, 2008
    Thanks for the advice, but it's the power supply. I asked two other tech support guys and they agree that it's the motherboard that's defective.
  • 84 Answers
Turbo-Cool makes a better power supply then all the rest . For total happiness even if you use two PCI-16 video cards ( CrossFire Ready, SLI Ready ) Turbo Cool 860-Watt Power Supply .
Posted on Jul 30, 2008
Dear sir, whenever the switch on the CPU its immediatly (With in 2 seconds)turn off, Power supply ok but CPU not booting. Thanks & Regards, shyam raj.
Hi Check that the power button is not stuck on or that the reset button is not stuck on as this will cause the machine to shut back down instantly i hope this helps
Andrew A
Apr 07, 2011 | ASUS Pentium 4 , Pentium 4, Pentium D,...
What procesors 64 bit will work with Abit IL9 Pro Motherboard Thanks Andy
The Core 2 Duo, Pentium 4, Pentium D will all work in the Abit IL9 Pro Motherboard.
Mar 05, 2011 | Abit IL9 Pro Motherboard
Computor shuts down for no reason. then I have to
Hi, Make double sure that your CPU isnt overheating , Your PC Turns off when it detects your CPU getting too hot , so it wont overheat and get damaged....Try using Realtemp or Speedfan to check your CPU tempreture..
Hope this helps bud
Happy new year :)
Jan 02, 2010 | Audio Players & Recorders
My custom pc came with a biostar p4 series motherboard and intel pentium 4 cpu seeing as they,re knackered i want to improve board and cpu any suggestions
Hi karl_buckley,
Well, my first suggestion would be to just get a new board. The reason I say that is it's not going to be much better regardless of upgrades you do. It hold the maxiimum of 2 gb for ram, and a P4 Intel CPU up to 3.2 Ghz CPU. Which is like an upgrade that will cost you maybe (if you find the parts) $50.00. You can buy a bundled motherboard with CPU from $50.00 and up. But, if you want to upgrade it, you can check HERE and find what is compatible with that board. At least you know what will fit.
Good Luck,
Nov 09, 2009 | Biostar P4M80-M4 Motherboard
VGA Problem
There are many possible reason why your onboard vga give 4 bit color in xp, the first reason is: did you install the driver of the onboard vga? if not then install the driver of the onboard vga and the vga give 16 to 32 bit of color in xp. Keep In Touch if you need help.. TY
Dec 08, 2008 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Midi Trouble with Reason
It is possible that your PC is too slow, but there may
(of course) be other causes
I have experienced a situation with Adobe Audition, causing
recording drop-outs when my PC got too busy.
To test this theory:
1) Shut down all unnecessary applications.
2) Go to the command prompt and disable the internet:
type: IPCONFIG /release.
to restart it later, reboot the machine or type:
3) Go to the task manager and stop all unnecessary
press: control-alt-del at the same time and then
choose the "processes" tab
right click on each process you don't need
and stop the process
4) You should be able to reduce the number of processes
into the low 20's, but you need to keep the following:
a) Your midi application (Reason etc) of course
b) alg.exe
svchost.exe (all of them)
system idle process
5) Now go into the control panel --> administrative tools ->
services and stop all unneeded services
(the system will not let you stop anything essential)
6) Don't worry about stopping tasks and services,
they will all restart to normal when you reboot the
7) Go back into the task manager and right-click your
midi-application. Increase its priority to HIGH,
but NOT real time, because this may cause windows
to hang.
8) If your midi acquisition improves, then speed is the problem,
otherwise, look elsewhere:
a) re-install audio and midi drivers
b) make sure the mixer and control applets are correctly
configured, i.e make sure the midi is not muted.
e) make sure the midi application is allocated the
max amount of memory, if it has a setting for it.
9) I am assuming that you are running Windows XP.
If your PC is too slow do NOT use Vista !!!!,
which makes things much worse, at least
by a factor of 4 to 1
Do not install XP service pack 3 either,
its bloated with anti-piracy **** and DRM.
10) Finally, for audio work, I would recommend
a minimum system with:
a) Pentium III 800 MHz or better yet a Pentium IV
at 1.5 GHz or faster.
b) One Gbyte of RAM to make sure your machine is not
disk bound. This is much more important than a fast
Disk is approx. 10 million times slower than RAM,
so this can become a very significant bottle neck.
c) Windows XP pro, SP2 (not 3)
d) Depending on your video card, i.e. the amount of
workload it handles for the CPU, you may also reduce
the screen resolution, and disable desktop effects
to speed thing up.
Adobe audition, for example will perform more reliably
on slower CPU's when the GUI window is kept small
in waveform or spectrum display during recording.
Good luck,
P.S. I use Adobe Audition for most of my recording and
audio processing. System = Core 2 Duo /2.4 Ghz,
4 Gigs of RAM (only 3 Gigs are accessible from 32 bit
windows XP), 1300 Mhz front side bus, 3.5 Terra Bytes
of hard disk, of which 1.5 Terabytes are configured as
Speed and storage is no longer an issue :)
not even for HD video processing.
Jun 01, 2008 | Propellerhead Reason 3.0 (991010004) for...
Upgrade from Pentium 3 to Pentium 4
what socket is the Pentium 3? Socket A. The sockets have to be compatible for example you can't upgrade a Dual Core for a Core 2 Duo because although the chipsets look the same the motherboard may not support the new instruction set. I had this problem recently as i wanted to upgrade my Intel Celeron D 3.02ghz to the Pentium Dual Core 1.8ghz and although the chips were identical and fitted perfectly in my mobo, the actual mobo i was using (foxconn) wouldnt work with it forcing me to buy an ASRock mobo and replace the entire system.
May 27, 2008 | Dell 2.8 GHz Second Processor for...
Computer reboots
Hi cool,
Is your Computer keeps on recycling from booting and never finish to load your OS?
As far as i know you got a problem with you CPU, your computer processor is overheating inside that's why it keeps your PC recycling it's power.
Try to go to the BIOS setup menu, and go to the cpu temperature and you will that your PC is heating up.
Hope it helps & give you an exact reason.
Feb 10, 2008 | Computers & Internet
Foxconn 661MX Motherboard Logo
158 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
