Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP500 ink tank cannot be recognized error U043
I replaced the magenta ink tank and got the message that the cartridge was no recognized so bought another new one, CANON OEM, and it still says U043 The following ink tank cannot be recognized I cannot scan either with it locked up like this and the stop/reset button does nothing when I hold it down for several seconds. HELP :( Canon MP600. Every time I replace an ink tank I get the message "ink tank cannot be rcognized." Usually after several tries it is resolved. However, I recently replaced the Cyan ink tank and the printer will not recognize it under any circumstances. I cannot get out of this error message. My Canon MP600 (less than a year since purchase) is now out of service. the black ink cartridge was replaced by a new one but the color one is still empty.i get this error even if i select black only option from preferences The printer will not do anything since it does not recognize the magenta ink tank, which has no evidence of any malfunction. In fact, initially when the ink tank is inserted, it lights up, signifying the printer is ready to print - then when the cover is closed, the printer flashes the ERROR - U150 - ink tank cannot be recognized. This is a canon brand ink tank in a 4 month old printer.
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Posted on Nov 30, 2009
  • mezzedup Dec 07, 2009
    yeah, good advice from solution 1 PITA though never buying another canon
    Sergeant:
    Champion:
  • 214 Answers
The best way is ask your vendor to rectify the problem since it is under warranty
Posted on Jul 30, 2008
4 Suggested Answers
SOURCE: MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
canon pixma mp600 geeft U043 fout melding terwijl de cartridge allemaal vol zijn
deze hebben volgens de leversansier geen chip
hoe los ik dit op hij herkent geeneen cartridge
hartelijk dank b.v
Posted on Oct 09, 2008
SOURCE: Canon MP600 error code U043
6A00
Posted on Jun 15, 2009
Canon mg5350s u043 error
Easiest solution is to buy an original cartridge, any colour and this will normally reset, otherwise your Google the problem and you should find a solution to disable this function, but chaeck reguarly as you wont get a warning that the cartridge is empty after you disable the function
Jul 15, 2014 | Canon PIXMA Office Equipment & Supplies
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Alarm light is lit -
Ok my printer is giving me the U140 message saying that ink tank cannot be recognized. The new ink tank is Cannon (not a off brand or refill). i think it is a problem with the chip reader port inside the printer not the ink tank chip. I feel this way because if you switch around the yellow and black 8 tanks, the printer accepts them without error.. soo if it was the ink cartridge i could be able to swap the black with the magenta and it should read it.
Sep 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Replacement Ink Gone WRong
Cartridge world gives you 90 days to return the ink tank. Take it back and get a replacement!
Nov 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,858 people viewed this question
old marine
old marine
