Question about Acer AL1715 17" LCD Monitor
Acer Second monitor
My second monitor was working fine. But i do know what happen now i just see black screen with a message Input not supported.
  • Anonymous Aug 07, 2008
    The screen is black, but you can see some light flashes along the edge. No images visible. AL1714
Input is either digital or anolog can't be both
Posted on Aug 04, 2008
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
'input not supported'
yes it will but u need to adjust it to 1024x 768 60 hertz in settings menu ok
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Hello so on my monitor i have two vga in slots and one of them works and the other keeps saying cable not connected and it stays a black screen so everytime i want to play on my xbox i have to unplug and...
Usually when a PC monitor like this one has multiple inputs, there is an input change button (much like the one on a TV). It might be hidden in a menu. Make sure that when you have both devices connected and turned on that you're switching to the correct input in order to view the other device. It's very unlikely that it will switch automatically.
If you're viewing the correct input and you're still not getting a signal from your Xbox, it could be a defective monitor connection. Try switching the cable first: use the cable that you know works and connect it to the second input to make sure that it's not a cable problem.
If the cable is fine but the second input still isn't working, the monitor input connector is probably malfunctioning. Depending on how long you've had it and if it's still under any kind of warranty, you may want to contact Acer for further support and see if they can either fix it or replace it for you.
Hope this is helpful!
May 08, 2011 | Acer P224W 22 inch LCD Monitor
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1715 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
