Screen jumps when you tap it straigtens out - Televison & Video
  • 12,061 Answers
OK ya have a "Dry Joint" or "Loose Connection" somewhere inside ya set... These can be a bear ... it may simply be a Plug & socket not mating properly .. or it maybe a component badly soldered... or... or... or... Hmmmm.. so unless ya got experience, troubleshooting this type of thing .. well then it's off to the shop... get a "Quote" and go from there.
Posted on Jul 30, 2008
In 3-2 the tombs when my partner in i have 2 run then jump then run the last jump what do we have 2 do so we dont keep fal
First after the cut sceen rapidly tap the "A" button, wait for the on screen prompt "X" or "B" and hold that button down untill you have cleared the pit and go back to rapidly tapping the "A" button repat this for the second pit and also the third however as soon as you land having cleared the third pit you will see another on screen propmt to press the left and right triggers at the same time and hold them down until sheva has pulled chris to safty.once you get used to doing this it is probably the best level for "harvesting" with 25 gems an idol and the granade launcher.
Jan 17, 2012 | Capcom Resident Evil 5 for Xbox 360
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
The touchpad is installed on HP notebook PCs.
You can "tap" and "double tap" your touchpad with your finger, and interact with the operating system in exactly the same way as clicking and double clicking on your mouse.
When using touchpad on your notebook PC, the cursor may jump, flicker, or double-click by itself.
Follow the recommendations in that HP document, or "disable" the TouchPad, if you don't like what it does.
May 12, 2010 | Computers & Internet
Tap function not working propery. Started off just being off a little bit tried to recalibrate it on the bulls eye. Nid not work (bulls eye just kept jumpping around no matter how many times you tapp it...
Have not solved the problem. The way I'm going to solve it is by buying another product. I have never been asked to pay for getting an answer to a product problem. Palm will not be a product I ever buy again! Problem Solved!
Jan 28, 2010 | Palm TX Handheld
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Dec 19, 2009 | HP Pavilion dv4000 Notebook
Driver side front caliper mounting bolt threds stripped on the sprindol. how do i fix? its a 2000 jeep tj 4.0 ltr need to do something to keep the caliper in place. should i try re taping or buy new...
If you can sucessfully trace the threads with a tap, that certainly is cheaper than the $400 option.
If you have to have another rotor though, you might can get one at a salvage yard for cheaper.
Assuming the tapping option is sucessful, also make sure your bolt threads are good before trying to use them again. If they need correction, you might can use a thread die to straigten them out... else, get some new bolts.
Hope this helps... Good luck!
Oct 06, 2009 | Jeep TJ Cars & Trucks
Dell Lattitude D800 with screen issue
This is either a loose data cable on the main board connection or the connection to the screen has shifted. The first is a easy fix and the second usually isn't. If you have bumped it or dropped it you can cause this. My hunch is it is the display but you can check to make sure.
If you tap along side the display while it has a image you may see it jump or even clear up with every tap. If it does that means it is definnitly the display.
If you tap on the bottom about where to the top edge of the keyboard ends towards the left side that is about where the connector is located. If it jumps or changes when you tap its your connector.
If tapping in either place does nothing then I would suspect the problem is in the display itself and will most likely require replacement. If it apears to be the connector the laptop needs to be partially disassembled and the connector reseated. That usually fixes the connector caused problem.
Jul 09, 2009 | Dell Latitude D800 Notebook
Screen shakes
i just tap the top of my screen and it stops
Jan 29, 2009 | Compaq Presario Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
IE Err
In my LG Manual, They IE error is water inlet trouble.
Possible causes
  • Water supply is not adequate in area
  • water supply taps are not completely open
  • water inlet hose are kinked
  • the filter of the inlet hose are clogged
Solutions
  • Check another tap in the house
  • Fully open tap
  • Straigten hose
  • check the filter of the inlet hose
Not sure if this helps, it's what is says in my book.
Good luck.
May 27, 2008 | LG WM1815CS Front Load Washer
Televison & Video Logo
Top Televison & Video Experts
