Question about Kitchen Ranges
Whirlpool gjsp84902 i have a whirlpool electric range and about 1 week ago it blew my breaker in the basement electrical panel i reset it and it seemed ok but i am sure that the bottom element is inoperative is their a quick check i can do with an ohmmeter that i can do before calling in a tech ( i am an automotive electrical tech so i have the tools and the smarts but no manuals/diagrams) i know its mounted underneath and accessed thru the back anything else i should know?????? Thanks in advance Dave Newell ps i see your a guru and for those that dont say it thanks for your help
  • 1 more comment
  • devilishdave Aug 01, 2008
    You where right the baking coil has resistance but has continuity to the oven frame i will find a new element somewhere tomorrow
    thanks for your time and effort.......
    Dave
  • devilishdave Aug 04, 2008
    Well well Mr Guru..
    the element was burnt missing a good 2 inches it had continuity thru both terminals and also to the oven frame/housing i replaced the element yesterday and now my wife loves me again.............
    Thanks a million for the help i bow down...if your car gets an electrical problem email me and i will try and help you out
    Thanks dave
  • Anonymous Mar 30, 2009
    I had the same problem with my lower element and it was replaced #9752294 but the stove is not coming up to temp. Also cakes are not cooking fully and it is the Accubake System stove.
    Our original element had two holes in it.
    Do you think there could be a defect in the replacement element?
    Thanks
    John
  • 5,911 Answers
The link I'm providing provides the necessary steps to replace an element in your oven (if this is the case):
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
It is common when elements go bad on an electric range to have them trip a breaker such as yours. The element are a resistive coil that can vary in resistance depending on model and manufacturer. If you wish to take a measurement to be sure, first, UNPLUG the range and remove the back panel. The terminals for the BAKE and BROIL elements are visible in the rear, each having different colored wires leading to the Electronic Oven Control (EOC) board. The board will have a separate relay for each circuit (one for bake, and one for broil). It is less common for a relay to short out, but it does happen. If this were the case, the element would stay on conterminously. That's why I suspect you element to be the cause of the problem. Disconnect the leads from the BAKE element and perform a meter reading across the terminal connectors of the element on the Rx1 scale. The element should show continuity if good. If it doesn't, replace it. Now, on the same Rx1 scale, take a meter reading with one probe on the terminal and the other on the outer shell of the element. If it shows continuity this time, there is a grounding problem with the element, and it will also require replacement. I hope this leads you in the right direction. Let me know if you require further assistance. Good Luck to you.
PS I appreciate the kind words. You're right, I don't hear it enough. It makes my day when I can help someone and they appreciate the effort.
Posted on Jul 30, 2008
Direct drive whirlpool washer has electrical odor and stops.
the burn odour and stoppage an electrical fault and coupled with a 20 amp circuit breaker tripping indicates a motor fault
Capacitors are tested with an capacitance tester and not an ohm meter as ohms is a resistance and not capacitance reading
When breakers activate it indicates a massive short or current draw and the problem could be in the windings of the motor
could be water getting into the motor at times causing the intermittent problem
I would suggest that you call in a service technician or an accredited electrician to check out the machine properly
Jan 20, 2016 | Whirlpool Washing Machines
My whirlpool oven will not open. I have held the start button for 5 second to toggle between the child lock and unlock modes but will not open either way. What now?
Try turning the circuit breaker (electric panel in basement or storage room) off, wait at least 10 seconds, then turn it back on. This may reset it.
Jun 25, 2014 | Microwave Ovens
Thanks for taking my question. Model Info: Whirlpool Accubake system electric range Super Capacity 465...... my wife moved the range to clean behind and it sparked at the plug and blew the breaker. ...
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Jul 26, 2011 | Microwave Ovens
Purchased a kenmore electric range around 1 and 1/2 yr ago ( 790.9437370) and i heard a pop. The heating element appeared that it was burned. My hubby just installed a new one, and again, the oven does...
check the circuit breaker for the house ..the breaker prob. blew ..if not ..unplug range ..remove the back panel to view all them wires an switches ..look at all of the wires an connections for burt or broken wires ..if all looks good ...their may be a thermal fuse located where the switches are .. look real good with a flash light ..you will find the problem ..you may need a volt/ohm meter to test voltage ..or thermal fuse ..let me know an good luck../joe/
Aug 29, 2010 | Kenmore Kitchen Ranges
I hace a 2003 Kenmore Electric Ran ge #790-95682. Five minutes after turning the oven on to preheat, I heard a loud poppong noise and spark near the left side of the burner controls on the display panel....
your bake element blew look at it to see if it is broken. if it is replace. the main breaker blew in breaker box .most likely .or a wire is burnt take off back panel and look .unplug first .good luck
Aug 23, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
Mar 05, 2010 | Electrolux Kitchen Ranges
Whirlpool Gold electric range.
Hello delmonico
Welcome to Fixya,
You said, when turning on the self clean option, after 1 minute, I get E 1 F5 on the display panel. What do I do?
Try this .
Turning off the power to the range at the breaker for 5 minutes and see if this will reset the system.
Display shows messages
Is the display showing a letter followed by a number?
Depending on your model, press OFF/CANCEL or CANCEL/
OFF to clear the display. See “Control Display” in the
“Electronic Oven Controls” section. If it reappears, call for
service.
Let me know how it goes.
Thank You,Huuum
Please remember to enter a rating!
Oct 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
F1 code. Stove is beeping
F1 defective touch pad or membrane. 1. replace touch pad or membrane ( this problem is usually the touch pad).
or
F! watchdog on board. 1. replace touch pad or clock assembly (also called the ERC).
Aug 25, 2008 | Jenn-Air SVE47100 Slide-In Electric...
SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
371 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
