Installing my webcam so i can be seen on yahoo messenger for the web
My webcam is all ready installed into my computer and seems to work ok and it works on paltalk aswell but i cant install it so that i can see people who also have webcams and are using them on yahoo messenger. Please can anyone help me with this problem
Before plugging the webcam you have to install the software driver first. After installing restart your computer and plug the webcam, it will detect the system as found new hardware just click ok or next then the system will update or installed the webcam. Mostly the software application are automatically appeared on your desktop. You can test your webcam by clicking the shortcut on your desktop or by using video call on yahoo messenger or using skype software. These two messenger will test if your webcam are properly installed and working. Have a nice day!
I am going to assume that you already have installed your webcam and can use it within windows with the software it came with.
I am also going to assume you are using yahoo messenger 10.
To activate your webcam in Yahoo! Messenger 10 in the top menu click Messenger, then from there select My WebCam.
Read the warning that should pop up, click OK and then select your speed preference and click OK.
Another box should come up showing your webcam view. It will monitor how many users are watching yor webcam.
Sounds like its looking at a video card and not the webcam software Make sure your webcam is correctly shown as the Camera Source in whatever program you are chatting in
Yahoo Messenger as below
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger. COMPATIBILITY WITH YAHOO MESSENGER Use Internet Explorer to visit this page to check compatibility and automatically download the latest webcam control
CONFIGURE SOFTWARE Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager. Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION Webcam connected Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING > Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
v
Normal
0
See section B. Yahoo
Messenger in the info below to setup the Audio & Video. Also send this to your family
and friends so they have their computer setup properly. Web Camera’s have to be
setup on the program they are to be used with.Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly. A.Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
Go to Tools,
then Options, and click on Audio Settings and set the Microphone
and Speakers to the computer Audio Card.
Then
click on the Video Settings.
The
camera if Installed Properly will come up and show a video picture.
Then,
on the bottom of the page click on Save.
The camera and audio should function properly.Your friends and Family will now be able to
see and her to you. B.Yahoo Setup:
After downloading and installing Yahoo Messenger(http://www.soft32.com/download_30.html
) set it up as follows:
Go to
Messenger at the top left and click on it.
Next
go down to Preferences and click on it.
Next
Calling and Devices on the right and set the Microphone and Speakers to
Next
go to the Test Audio section and(in blue writing) click on“Open the call setup assistant” and follow the instructions on the
left window.
You should test the compatibility of your web cam with Yahoo! Messenger. I recommend you to install drivers for your web cam. These are usually found at the web cam manufacturer;s web site. Hoping your webcam's compatible with Yahoo! Messenger!
Normal
0
Go to Tools,
Then
The
Then,
After downloading and installing Yahoo Messenger(http://ca.messenger.yahoo.com/download/
Click
on Messenger at the top left and then go down to Preferences
and then the Preference Window will come up.
Next
click on Calling and Devices. In the Calling & Devices
on the right and set the Microphone and Speakers to the computer
Audio Card or sound device installed in the computer.
Just
below that, go to the Test Audio section and(in blue writing) click on“Open the call setup assistant”
and follow the instructions on the left window.
Then
after completing the Audio Setup, go to down and click on Webcam.
After
make necessary settings, click on APPLY, then on OK and it
should be ready to use.
Normal
0
See section B. Yahoo Messenger in the info below to setup the Audio & Video. Also send this to your family
Go to Tools,
Then
The
Then,
Click
Next
Just
Then
after completing the Audio Setup, go to down and click on Webcam it
should BRODCSAST and you will see your picture.
To
Chat, click on MESSENGER and then
After
make necessary settings, click on APPLY, then OK.
Then
click on MESSENGER and go to my WEBCAMready to use.
Normal
0
See section A. Skype in the info below to setup the Audio & Video. Also send this to your family
Go to Tools,
Then
The
Then,
Click
Next
Just
Then
To
After
Then
Black screen in Veo Digital Studio or Yahoo! Messenger.
Veo Digital Studio:
Start the Veo Digital Studio and then click on the "Take a Snapshot" button. The camera light should turn on.
Click the "Settings" button and then click the "Advanced Settings" button.
On the Video Quality screen, click the "Defaults" button to enable the default settings for the camera.
Click "OK" and then "OK" again. You should now see the live video on your screen.
If you still see a black image on the screen, try disabling the overlay feature to see if this resolves the issue:
Unplug the camera from the computer.
The Veo Digital Studio will indicate "Digital Video PC Camera is not connected to this computer." Click "OK" to this message.
Click the "Quick Fix" button and then check in the "Disable Overlay" checkbox. Click "Fix it" and then close out of the Veo Digital Studio.
Plug your camera back into the computer and then try the Veo Digital Studio again.
Yahoo! Messenger:
Make sure that your camera works and you can see yourself by following the steps above for the Veo Digital Studio.
Close the Veo Digital Studio and then start Yahoo! Messenger.
In Yahoo! Messenger, click on Tools->Start My Webcam.
If you see a black screen, in the My Webcam window, click on File->Preferences. On the left side of the Prefences window, select Webcam. Click on the "Camera Source" button. In the Camera Source drop down menu, select the Veo PC Camera or Veo Web Camera and then click OK.
Click on the "Camera Settings" button and then click the "Defaults" button.
Click "OK" and then "OK" again to close the Properties window. If you still see a black screen in the My Webcam window, please contact Yahoo! for more assistance or refer to the Yahoo! Messenger Webcam Help page at:
I can see only my photo on my web cam when I open yahoo messenger and select view my web cam
