Question about Electrical Supplies
Gas weedeater wont start
Weedeater wont start has gas fire to plug fule in tank kill switch is ok
  • 550 Answers
Assuming weedeater brand weed eater, the carb. has a filter screen, that blocks and does not allow the pump to push sufficient fuel. A phillips head screw on the side of the carburettor secures a square plate, remove the screw and plate and gently brush the screen clean, dirt collects on the visible side.
Dirty foam filters if fitted change the fuel mixture and make it too rich to run.
and the fuel mixture knob, although secured by a tension spring, moves and may need to be readjusted
Posted on Jul 30, 2008
Hs56c edge trimmer wont start have fire to plug and fuel could my kill switch be bad causing it not to start
If you have fire to the plug and the plugs gets wet with gas when you are trying to start it,, well ..if this is true, you have a compression problem.
The 3 things a internal combustion engine needs to run are.
1. Timed Spark
2. Correct fuel/air ratio
3. Good compression
If the kill switch was bad, you would not be getting fire.
Jun 06, 2017 | Garden
1993 jeep cherokee turns over but wont started has fire and gas
Crank position sensor or knock sensor may be faulty.
Feb 16, 2014 | Jeep Cars & Trucks
I have an 84 K100 that will not start. The bike has set for 1 to 2 years with the same gas. The bike was my brothers. I drained the gas from it and replaced with new gas. The bike will start and run as...
drain out all of the old gas first, put in fresh fule fully charge battery and retry starting her up, if no luck starting unclip fule pipe from injector rain and cranck motor over if fule spills the fule pump is working ok, pull off ecu plug and spray with wd40 all plugs and refit check spark do not let spark plug hand loos this must stay earthed or it can wreck the ecu if motor starts up, when it starts up some injuctor cleaner in fule tank and run engine up
Nov 12, 2010 | BMW K 100 Motorcycles
Hi, I have a Husvarna 357XP chain saw. It wont start. Checked whole thing: Compression, bore , piston Carburetta Spark plus fitted new plug Mixture strength correct. Fule flow fine It was working...
take the plug out and warm it up inside your oven at 125 degrees for ten minutes. reinstall and try again
it works for me and tells me the electronic coils is starting to go bad
Aug 29, 2010 | Husqvarna Garden
My Ryodi Weedeater Has No Fire To Plug Put A New One In
The plug receives its fire from the coil module which is mounted next to the Flywheel. It will have to be checked. If the unit has a kill switch, the wiring to it needs to be checked too. The important thing about the coil module is that the pickup legs on it need to be about .012" from the magnets that are inside the edges of the flywheel. There's always the possibility the coil has failed, but they don't very often. Check the air gap as stated at the flywheel and make sure there are no bare or chafed wires to the kill switch going to ground somewhere.
Jul 18, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Wont start,not even firing,plenty of diesel both batteries r fully charged it has been of road for 2 months due to having a new clutch fitted
you may have an air leak in a fule line and the derv has ran back to the tank, bleading the fule line may help that or the heater plugs are not working very well in witch case it wont start,,,
Mar 10, 2010 | 1999 Isuzu Trooper
I have real bad trouble tryin 2 start my crf450 hot or cold the bike just dont want to start, but when you do finally get it going its sound, but then when turned off its stil the same any ideas
i would start by having a compreshion test done on the engine if it has good compreshion start looking for a fule problem clean out the carbs and fule lines and change any filters in the fule tank a new set of spark plugs never hurts as well test for a good spark by jaming a spark plug down on the engine caseing and crank the engine over if its a good bright spark thats working ok also check the ignishion switch and kill switch clean them both up with switch cleaner just squirt them well and work the cleaner well into the switches it wont hurt them and it will do them good to be have a bit of lub in them as it keeps the wether out of them
Jan 19, 2010 | 2003 Honda CRF 450 R
06 ttr 125 will not start , Kill switch button
If the plug is firing OK then the Kill switch has no connection with the problem.
The problem seems to be the gas supply. There are three things required to start a gasoline engine. The gas, the spark and the minimum RPM. Two of these are available and the third gas is seemingly missing. So, please check if it is getting the required gas. Since gas is gravity fed in bikes, make sure it is reaching the carb in sufficient quantity.
Dec 25, 2009 | 2003 Yamaha YZ 125
Truck has been sitting fo about a year.added fule .charge battrie
Turn the key to the start possition and listen for a small humming noise coming from the gas tank if there is one the fuel sending unit is ok if no sound even if you have gotten real close to gas tank and heard nothing then its the fuel sending unit ok
Sep 04, 2009 | 1989 Chevrolet Suburban
Bike shut off on the freeway and wont start again.
Got gas? Got water in the gas? Drain the carbs and fuel line.
Check for spark. If no spark then check again with a new plug.
Is the kill switch on? Does the side stand have a kill switch? Is it working properly? Tip-over kill switch on your bike? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
Are all wires clean and with a solid connections? Check the loom. Any abraded wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. With a little luck this will get you back on the road.
Please rate this solution. Thanks!
Apr 05, 2009 | 1995 kawasaki ZX-6R Ninja
Electrical Supplies Logo
587 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
