Question about Sony Walkman NWZ-S616F MP3 Player
Volume Hi~ My daughter has this mp3 player and the volume just stopped working. We have reset it and nothing happens. Any suggestions? And no I haven't thrown it on the floor yet, but have seriously considered it. thanks.
  • roberthambly Aug 10, 2008
    I have a walkman with no volume. The down volume worked, but the up volume stopped working. After pressing the volume rocker switch, I eventually ended up with a perfectly functional player with zero volume. I pried off the volume control rocker plastic, and there are tiny two buttons underneath each side of the rocker. The Up volume button appears stuck in the 'pushed in' position or the switch is broken. If I can open the case and switch the volume up, I can cover the volume control, and use an external volume control (on my headset) to cut the volume down. (or I can just buy a new one (bigger) and sync all my audio to a computer and then to the new one.
Buy a new phone
Posted on Aug 19, 2008
My gogear 8gb won't stop updating
Connect the player to power and pc with the device manager running. Reset the player by holding the off-switch and the volume-+ (plus) switch, and as soon as the player shuts off, press and hold the volume- - (minus) switch. The philips device manager should come up now and recommend a repair, let it do so.
Jul 05, 2009 | Philips GoGear HDD1830 MP3 Player
Barbie girls mp3 player. I cant find the volume control limit switch. I've seen it before when we first received this. Now my daughter wants the volume turned up and I cant find where to do it. Any...
You have a round button on your Barbie Girls Mp3 player. Right? Well, you have a round button in the middle of the circle that is Pause. On the right and left hand side is the back and forwards buttons. The up and down buttons on it is the volume control. Up is louder. Down is softer. Hope that helped you, deary.
Apr 21, 2009 | Mattel Barbie Girls MP3 Player
Volume is all the off and will not turn up
sound like ur volume avls(volume limit is on) so go to settings thengo to common settingsin that the second one down should be AVLS or (volume limit) contoller. also does it go up at all or does nothing happen.
Apr 17, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
I am not sure what happened but my daughter was pressing buttons and now my mp3 player is frozen and I cant even charge it. I cant turn it off and my pc doesnt even recognize it when i turn it on. What do...
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Dec 16, 2008 | Philips GoGear SA3125/37 MP3 Player
Hi, please help. my sony nw-hd5 mp3 has suddenly stopped working. the screen just went blank. everytime i press play nothing happens. its not the battery i have charged it. the problem ocurred...
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
also, check Sony's website - they have THE BEST website of any mp3 manufacturer - bar none.
Jun 26, 2008 | Audio Players & Recorders
My philips gogear wont turn on
Disconnect the GoGear from the computer
Reset it first (pinhole in back - safety pins work best), even if nothing happens - just to be on the safe side
Nothing will happen still, but we are OK
Make sure the power is off, and hold in the volume + button, reconnect the GoGear to the computer while holding in the volume + button, and continue holding volume + until a window pops us saying Found New Hardware Wizard
Go through the Found New Hardware Wizard, and the GoGear should be working again - the player will be revived
Write me back if this fails to resolve the problem.
-Tha Mp3 Doctor
Jun 17, 2008 | Philips GoGear HDD6330 MP3 Player
Loss of sound
Try the following:
1) Check your headsets. Use another player to test it. If it works then the problem is within your MP3 Player.
2) Adjust the volume. If it does not work...
3) Reset your MP3 player by pressing the reset button found below the volume buttons.
4) Unlock the hold switch.
Jun 14, 2008 | Sony NW-E002 MP3 Player
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Dead MP3 Player?
MyMusix's PD-6030:
If you have a Windows-based computer,
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Nov 13, 2007 | MyMusix PD-6030 MP3 Player
Iriver
Reset, firmware upgrade
Oct 11, 2007 | iRiver H10 MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
189 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
