Panasonic pt51sx60a ,bottom of picture bowed color has shadowy hues of blue ,occasional warping of picture ,hard to watch
  • jacklucas Sep 09, 2008
    Yes my problem is similar only the bow on the right. Same blue shadows. Help
My tv is panasonic pt-51hx41e hay can see picture but come on disturtion in tv ,they side that is mother board $380.00 hay need to now is true,or hay can buy part and ware?
Posted on Nov 18, 2008
What are signs of picture tube going?
Signs of a CRT going old, are bad focussing, unnatural colours and hues of a certain colour (red, green, or blue) if you watch black/white pictures. In colour pictures, black sequences also show hue.
Jun 13, 2014 | Panasonic CT-32SL14 32" TV
Picture has a white hue. Is this a bulb problem and if so how do i know which one
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2011 | Philips 55PW9383 55" Rear Projection...
Just tonight we were watching TV and the screen got darker. Picture is still fine, just got darker, on some channels the top and bottom center bow in toward the center a little, easy fix or a lot of...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Panasonic PT-51G53 51" Rear Projection...
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngSOLUTION
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Pink Hue
it must be the problem of convergence in the tv.
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
May 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
319 people viewed this question
Top Televison & Video Experts
