Question about Creative Labs ZEN SLEEK MP3 Player
Screen wont turn on
I droped it and it wouldnt work so i just let it run dead then when i charged it the screen wont come on it feels like it is tring to find what on it every thing esle works fine but i dont know if the headphone jack works because i dont have a screen that shows anything on it its just black i want it to work again soon so please help me and thanks
  • vang lucky Nov 15, 2008
    i droped it and it hit the table and hit the ground and the screen didnt work but every thing else worked fine i could still listen to music
  • Anonymous Mar 09, 2009
    dropped it
I was just having the same problem with my zen player thanks for the advice it worked!!!
Posted on Oct 01, 2008
  • 20 Answers
Push a pin intothe tiny reset hole on the bottom of the player. If that doeasn't work, push the reset hole again while holding down play and power buttons. Then run "clean-up" on the recovery screen which should appear.
Posted on Sep 16, 2008
  • Kimberly Reyna
    Kimberly Reyna Jun 09, 2014
    Can you help me i dont get it
My Iphone 4 screen wont work
You would need to get it repaired/replaced either way. You can either get it repaired by a third party place that will repair it for you (not sure how much they would charge) otherwise you could just get it replaced from Apple by paying the out of warranty service fee as it would have liquid damage to it.
Dec 15, 2012 | Apple iPhone Smartphone
1988 honda accord dx stalls after starting when cold, when tring to restart smells like fuel and wont start
check if the air intake is clear , no cracks/split etc in the pipe work , air filter is clean,if look ok then i'd get the stepper motor checked out as a first step
Jun 11, 2017 | Honda Accord Cars & Trucks
I was driving and the car just dead the rmps droped really fast then just died out. the wouldnt turn over. it has a spark its sucking air the starters clicking everything sounds fine but it wont start....
Unfortunately this is indicative of a failed alternator. When teh vehicle is started teh battery provides teh initial power to turn over the starter and then it stops and allows teh alternator to provide the power required to keep teh engine running (fire needed requires spark, air, and fuel) When an alternator dies the battery has a RCA or reserver capacity amps that indicate how long the car will run on batter power only. Since you indicated a sudden decrease in the car and a dead conditions with failure to turn over then it leans towards the bad alternator. Depending on your mechanical ability you can remove the alternator and have it checked at the local aprt store. Try jumping the car and then ave someone follow you to the part store.. yo uwill like have to rejump it several times... if you arent comfortable removing alternator. If your battery has been running the car on RCA than having input back into it from teh alternator then its likely it is burned out... So replacement of alternator and battery are recommended.
Jul 14, 2010 | Subaru Impreza Cars & Trucks
I cant turn it on i keep hitting the power botten but it is not working and i tried charging it how do i even turn it on
im afraid that its dead... did u drop it alot or submerse in water>? same ting hapened 2 my fone last month...droped it once nd it wouldnt turn on.. it was a motorola razr
Oct 14, 2009 | Cell Phones
My fone wont let me touch the screen but will let me answer calls
if the screen is black press one of the buttons to light up the screen ... and if you have a stilus use it
Jul 03, 2009 | LG KU990 Viewty
95 Chevy S-10 starting issues
If the engine is turning over and it still wont start try shooting a little starting fluid in the air cleaner to see if it will run .. if so your fuel pump is either bad or the fuel filter is getting dirty.. thanks and holler if you need more Jerry
May 11, 2009 | 1998 Chevrolet S-10 Pickup
My ipod wont turn on or charge.
More than likely the battery just needs to be replaced. I let my nano go dead and it was doing the same thing. So just get it replaced and that should fix your problem.
Mar 23, 2009 | Apple Audio Players & Recorders
ENGINE CRANKS BUT WONT TURN OVER
you meant its a NO CRANK engine.
silent starter, say the word silent.
even the starter relay must click.
and if head lamps die, so will be the starter.
due to a dead battery,
sounds like a bad battery to me. dead or only
DISCHARGED.
if the Charge/battery lamp is off in the cluster driving. its ok. the alternator.
starter car with the jumper cables connected
and not next day.
only live jumps matter. or you go know where.
if you want to walmart they have tool there that
tests the alternator
battery
and for phantom drains all in 6 min work, the tool does all the work.
if the battery is charged, it will crank I bet
its discharging.
for 1 of 3 reasons.
1: its bad.
2: the charge system is dead.
3: phantom drains, it goes dead as you sleep
the head lamps dead is the big clue there.
Mar 19, 2017 | 2002 Jeep Grand Cherokee
My phone will not turn on at all.
You should take the phone to a mobile service center and have it diagnosed first
Sep 03, 2008 | Nokia 6288 Cellular Phone
Camera wont turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 27, 2008 | Canon PowerShot S45 Digital Camera
Creative Labs ZEN SLEEK MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
