Question about Zenith B13A02D 13" TV
Will not power on
The above TV worked fine until a lightning storm. The house is equipped with capacitors in the panel for absorption and no other issues developed in the house.
The AC runs up through the cord to the board and the fuse is good. There are no problem spots ( burns) on the board. The on/off micro switch operates well.
The tube looks fine so I'm guessing that a small problem ( open circuit) exists in the power supply.
I have an electronics background but without the skematic I'm clueless.
Any suggestions?
Thanks.
Ken Kuehn
  • 1 more comment
  • kenkuehn Jul 30, 2008
    The HOT Transistor you speak of. What number is it on the board or what are the values or color or size?
    Thanks.
    Ken Kuehn
    Brand name Zenith Model #B13A12D. I believe it is item Q402 on the board.
    Ken Kuehn
    Model # was wrong. It is B13A02D
    Master:
  • 382 Answers
This could be possibly due to a power surge..So i expect a fuse burn or blown IC on the board..Make a step by step inspection of the circuits on the board you can easily make out the defective IC or resistor..Thank you!!!...
Regards!!...
Posted on Jul 30, 2008
  • 2,071 Answers
This symptom caused by shorted (HOT) Horizontal Output Transistor,change this transistor,so it will power on again..
hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Jul 30, 2008
    click for the sample picture guide of (HOT) transistor this near to flyback,give me the brand name and model number;
    Phillips F8 chassis
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Jul 31, 2008
    Check that transistor if not short Q402 it is better you
    take it from the board test it with the use of multitester in supply section
    look for the STR IC it has 9 pins take it change it with identical rating,that
    IC is power surge protector ,i have a service tips of Zenith troubles,below and
    a downloadable manual...
    Dead Unit has no life at all. We have had several of these
    all having no power / no click from the ON/OFF relay or the Degausing Relay
    Using STR53041 Regulator Always replace: CX3413 = 22mf 63V, CX3416
    = 100mf, 25V, RX3404 180k (use 1/2W). Also check:
    RX3407 = 47 ohm,1W, Rx3408 22 ohm, 1/2W QX3401
    121-1348 (use ECG184 or one of many other transistors with similar spec's
    listed in the ECG guide under TO-220 and TO-220J case styles 4 only (A 1Amp
    rating is required). If that doesn't do it replace ICX3431 - STR53041.
    Zenith B13A02D
    Manuals, Support and Troubleshooting
    Regards,
    VOTIT
My Emerson lf46iem4 46 inch tv stopped working after a storm... What part would I replace to fix it?
IT COULD BE THE POWER SUPPLY GOT SHOT OR THE TUNER DEPENDING ON THE CONNECTION WHEN IT WAS IN USE .SOME TIMES THE TUNER GOT SHOT WHEN THE SET IS CONNECT WITH THE COAX CABLE LIGHTNING WILL SURGE THROUGH THE CABLE IF IT IS NOT GROUNDED PROPERLY ...GOOD LUCK
Oct 12, 2014 | Emerson Televison & Video
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
Wont power on
you could have bad power supply capacitors, what is the TV model #
Jun 26, 2013 | Samsung Televison & Video
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Jun 28, 2011 | Sony Televison & Video
Tv does not turn on after the storm
It is most likely the power supply burnt out. The capacitor's inside are made cheaper than the o'l days and get overheated easily. You can test capacitors with capacitor tester and service manual. You can test power supply output voltage with just a voltmeter
Sep 10, 2009 | Televison & Video
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
Maytag drier model MDE5806AYW
hi thanks for the question i would guess the motor but man thats a hard one if the dryer was hit by lightning it could have caused a fef problems myself i would call my insurance company tell them you were hit before you call the insurance check all appliances in your house you may find other problems thanks the appliance doc
Jul 22, 2008 | Maytag PYE2300AY Electric Dryer
Zenith B13A02D 13" TV Logo
106 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
