Hello
Probably a power supply - if you open the back of the tv (if you have electronic experience) find the power supply look for bulged capacitors and replace them.
power supply unit problem you have bad caps (capacitors) change all the caps or at least the ones that are leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf.
THANK YOU FOR VISITING FIXYA
