Question about Avanti FF100 Top Freezer Refrigerator
Avanti refrigerator Model FF991W/FF992PS -STOP WORKING
less than a year old, the suddenly just stopped working.
I turned off for 5 minutes ( by disconnecting the power cord as well tuning the power from within the refrig) only the light and the fan is working.
  • Connie Lott
    Connie Lott Feb 02, 2009
    had a similar problem however the freezer worked and the icebox did not, took off the back inside the freezer part and found ice
  • 3 Answers
SOURCE: Avanti compact Refrigerator NOT COOLING
call the number in your service manual. they'll ask you to sent the receipr, the silver sticker on the back of the fridge, and a piece of the outlet cord so they know it's not in use. they'll ship you a new fridge. WOW!
Posted on May 17, 2007
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
SOURCE: Under counter beverage cooler
It might be ice around the fan. Try defrosting it. This has been happening to mine, even through it is supposed to be 'frost free'
Posted on Feb 22, 2008
  • 87 Answers
SOURCE: avanti issues
Take this unit back even if you bought it used and get a new one it is still under warranty.
Posted on Oct 07, 2008
ailia
  • 175 Answers
SOURCE: I have an Avanti outdoor refrigerator. It's about
Try to place on flat ground surface, u can balance its weight. Check compressor fan if its making noise.
Posted on Nov 05, 2009
Frig turns off unexpectedly and you have to manually turn switch all the way off and then back on and it starts running again, what could be the problem
Hi, it sounds like you have a thermostat / switch problem one or both could be the problem best get it looked at.
Apr 28, 2016 | Avanti FF991W Freestanding...
Recently our refrigerator stopped working (ice cubes were melting) and then started again when I turned the freezer dial from 5 to 7. The next it stopped again, this time for several hours. Everything...
I would replace the thermostat, cooling control to the unit, it is sticking. Call your local parts distributor to get the part. This model is on micro fiche and not made digital yet. Unable to locate without a production number from the sticker inside your unit.
Hope this helps
Jul 13, 2011 | Admiral Refrigerators
Refrigerator model 309YBT quit working on Friday
Good day,
You did not say if it was running or not.
If not running at all, then it may be the cold control, (thermostat) that has failed. You can remove it, jump the 2 wires going to it, and see if it runs and cools.
If so, you may be able to contact your local appliance parts house for a replacement.
However, if running and not cooling, then 2 options.
1. If under 5 years, sealed system should be under warrant. Call your selling dealer for details.'
2. If over 5 years, not price effective.
Nov 16, 2009 | Avanti 309YBT Compact Top Freezer...
Nov 05, 2009 | Avanti BCA5102 Stainless Steel Compact...
Avanti microwave. Panel not working, alot of beeping.
sounds like a panel issue for sure.
if the microwave is over 5 yrs old I would recommend replacing it
newer microwaves use far less power than before.
and they are not too expensive
May 27, 2009 | Avanti MO7180TW 700 Watts Microwave Oven
My fridge is a Fisher and Paykel and the lights that control the temperature wont stop flashing. I have tried turning it off but I have no idea what is going on. How can I fix this
Hello kadenmeister ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your fridge is a Fisher and Paykel and the lights that control the temperature wont stop flashing. And you have tried turning it off but I have no idea what is going on. How can you fix this!
Try this rather than just turning it off.
This can reset the system.
Turn off the fridge and then unplug the fridge and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It should reset the system!!
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Please remember to enter a rating before you sign out!
Thank you Huuum
"Let me know how it works out."
How old is the Fridge?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You, Huuum
Please remember to enter a rating here when you finish!
Thank You
Sep 24, 2008 | Fisher and Paykel Refrigerators
Ice maker not working
Hello bnelson488,
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Huuum.
Here is an interesting article I just read.
Repair or replace?
Sep 04, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jan 15, 2008 | Avanti 310SST Compact Refrigerator
Avanti FF100 Top Freezer Refrigerator Logo
256 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
