Question about Refrigerators
Dometic R V refigerator model RM2611. Will not cool on gas or electric. The unit that has the filler plug on the end(Looks like a thermos bottle on its side) gurgles when supposed to operate. Unit lights the gas when turned on to gas, and seems to try to operate when on gas. My service depot says that the cooling unit is no good and has to be replaced. What do you think. Hank
  • hankkyle Jul 30, 2008
    Spelling error: -Seems to try to operate when on ELECTRICITY.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR REFRIGERATOR?
Dometic R V refigerator model - small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Posted on Jul 30, 2008
Dometic RM2611, Freezes fine, Refrig OK on AC, but warms up when on LP gas. Can I safely increase the orifice size from #53 to #58? Thinking that will increase the flame and produce more heat.
Check the gas regulator and the lines for particles of dirt. You have modified the refrigerator it is going to take some work to find what is wrong. Don't modify the orifice from what it calls for.
APPLIANCE 911
Aug 27, 2016 | Dometic Refrigerators
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
How to remove a dometic rm2611 refrigerator
remove cover from outside unplug AC and shut off gas remove line then unwire take picture first remove screws on bottom holding it in then remove trim on front top and bottom have screws remove
Jan 19, 2014 | Dometic Refrigerators
RECHARCHING MY DOMETIC RM2611
Hi, it is not as simple as recharging when it comes to an RV fridge. If you have lost your pressure then you need a replacement cooling unit. A Cooling unit can normally be changed in approximately 2 hours with no specialized tools needed. Our cooling units come standard with installation instructions. Arcticold cooling units are Bran NEW not rebuilt. Our Products are unmatched in quality and performance. Check us out
Jan 17, 2014 | Dometic Refrigerators
Recharging my dometic rm 2611
closed system replace cooling unit
Jan 17, 2014 | Dometic RM2620 Refrigerator
My Dometic refrigerator model # Rm2652 does not cool anymore. The element heats up on both gas and electricity. I noticed an amonia smell and there is yellow matter at the bottom of the stack where the...
Your cooling unit is done, and will need replacement. I will urge you to take down model and serial number and go to their site, or call Dometic , ( www.dometicusa.com) 1-800-544-4881, and inquire whether your unit falls into the recall on some of those models. You may end up with a new cooling unit, free of charge.
May 23, 2011 | Dometic RM2652 Refrigerator
REFIGERATOR WON"T WORK ON GAS
hi, here is a link to a service manual for that unit. there is a "Common problems page" if this is a new unit for you then you need to be aware that these units must be level to work (get cold) correctly.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jan 16, 2011 | Dometic RM2652 Refrigerator
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic rm2611 quit on the road today all lights
If the fridge is complete dead (no lights no fan, no compresor,etc.) looks like there's not power in the unit.Check if theres power in the oulet if you know how , if you don't put the fridge in an oulet that you know is power , if still doing nothing probably the cord is broken or burned and the power doesn't go throught it from the oulet to the fridge.
Apr 27, 2009 | Dometic RM2620 Refrigerator
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
