Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
After a few minutes picture shrinks to single line on screen and then powers off
TV is about 5 years old. When you first turn it on, it has a clear bright picture (normal). After a few minutes the screen shrinks rapidly to a single line and the tv powers off (reminds me of the old B/W Zenith console my folks had when I was a kid). Second and repeated attempts to turn it on result in the same, only the time before the screen shrinks gets shorter and shorter until it just turns on, flashes the single line and shuts off.
I would like to know if this is a major repair or a simple repair and approximately how much.
Thanks,
Mike
  • 4,234 Answers
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Dan
Posted on Jul 30, 2008
Flat screen tv has picture in diagonal lines for the first 5 minutes when its turned on
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 12, 2015 | LG Televison & Video
Panasonic TV picture shrinks to a line
There is an IC which controls the vertical deflection and over the course of a few (or 8) years with the set heating up and cooling off some of the connections work their way loose causing the symptoms you describe.
If you were to bang on the side of the set you could likely "pop" it back in but this is not a good solution. The vertical IC needs to be re-soldered. This is especially common in Panasonic sets. About 10 minutes with a soldering iron should have it worked out.
If you're handy with a soldering iron I can tell you what to look for.
Oct 09, 2008 | Panasonic CT-32G14 32" TV
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Picture shrinks on white areas
Is this a power supply problem? You bet. Also old age.
Jun 30, 2017 | Philips 27RF50S 27" TV
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
JVC picture turns into a single line in middle of screen.
This is caused due to random falure of vertical scan circuits. It generally is caused by dried out capacitors or bad driver IC. Unfortunately it will get worse. If you fail to turn the TV off quickly you will burn a permenant horizontal line on the tube. Trip to the repair shop I am afraid.
Nov 30, 2009 | Televison & Video
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Projection picture problem
I am having the same problem on my 9p5031c101, ver interested in the solution!!! sjoney@sunnenlink.net
Aug 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
