Question about Gateway Computers & Internet
Is it ok to do the "Have you created your Gateway Recovery CDs and "Welcome to Gateway & BigFix?" It popped up on my labtop in Oct.2007 and today 7/29/08. I just feel insecure and that is why I am asking.
  • 33 Answers
Yes, if you have a Gateway computer it is designed to give you a prompt to create recovery discs in case of a problem.
Posted on Jul 30, 2008
Gateway login
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both.
Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page.
Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make.
Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 18, 2013 | Computers & Internet
Enter password unlock system
Log on as usual.
Method 2
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html
Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html
password cracker free
May 03, 2013 | Gateway 504GR PC Desktop
How do i reset my gateway mt6705 computor back to factory setting
Step 1:
Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management." Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications. A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set. Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created. The factory default installation will then be moved over to the hard drive. Click "OK" in the box that appears and wait for a second Gateway restart. Several minutes will pass as Windows "starts for the first time." When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again. Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next." Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up. Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish. Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly. This will likely take several minutes, so leaving your computer for a short time is fine. Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management. Once completed, your Gateway is good to go and ready at factory settings.
Feb 25, 2013 | Gateway Computers & Internet
I factory reset my gateway zx series all-IN-ONE because the recovery disks i created wouldnt work.then i reinstalled windows and now i have nothing in my programs list n i cant log in cuz they want a...
Hope this helps.
Jan 21, 2013 | Computers & Internet
I want to know how to restore my DX4200-09 to factory settings?
· Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management."
· 2
· 3
· 4
· 5
· 6
· 7
· 8
hope this helps
Jun 25, 2012 | Gateway DX4200-09 PC Desktop
Will the 2009 recovery disks we had to purchase in 2010 for my son's laptop (lost operating system within first 5 weeks of purchase) work for my gateway w6501
In general, recovery disks are designed for a specific make and model of computer, or a narrow range of computers. This is required by Microsoft and others in order to prevent piracy of the operating system and bundled software.
As a result, recovery discs for one PC will not work in other PCs.
If the Gateway PC is still running, you may be able to create recovery CDs from it. If not, you can order the recovery CDs from Gateway.
Read more here:
http://support.gateway.com/s/software/medialess/faq/suppage01su44.shtml
Apr 21, 2011 | Computers & Internet
Cannot find my recovery disk for my gateway mp8708. need some guidance. Got rid of several old computers over the holidays and expect that disk got put with one of the ones I gave to Goodwill.
Gateway has a site on the topic
If your system is intact, you can create the recovery CDs, following the instructions.
If not, you need to order a new set.
There is no legal place to download recovery CDs, since they contain copies of the Microsoft OS.
Apr 19, 2011 | Gateway MP8708 Notebook
I use Gateway recovery utility to create recovery discs. First disc is DVD, then from 2nd disc on it asks for CDs. After disc 7 it gives error 203, regardless if i insert CD or DVD. Did i complete the...
There is an issue withe Gateway/Acer Recovery management that originaly came with Vista http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CC0QFjAA&url=http%3A%2F%2Fsupport.gateway.com%2Fs%2Fissues%2F260121793.shtml&ei=-rRuUvjJB6Op2QWL-oDwBA&usg=AFQjCNFZVoKUSHCT51xHWAR6kpXwvFP9gw&sig2=NTGSgzIeXdfaVmcJdzzZPw&bvm=bv.55123115,d.b2I&cad=rja
Mar 09, 2011 | Gateway MD2614u Notebook
Bootmgr is missing on Windows XP System. Gateway
Download this Recovery Console BootCD
http://www.thecomputerparamedic.com/files/rc.iso
Burn the image (ISO) to CD.
Boot from the newly created Recovery Console BootCD
Log into the Administrator account (press 1 then press enter)
On the command prompt type: chkdsk c: /r (and then press enter) Note one space after "c:")
Once CheckDisk has finished repairing the faults, type Exit, and then Restart (remove the BootCD)
Mar 29, 2010 | Gateway ML6721 Notebook
Computers & Internet Logo
123 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
