You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in Windows 8.1 x64 using VueScan!
If you just got a new computer that happens to be windows 7 64 bit, and you've had this scanner for some time. That would be the reason why the scanner won't install, as the disc that came with it is out of date. I checked Canon's driver website if you (canon.com > support > selected your model > drivers and support) and it looks like there are no windows 7 64 bit drivers available. However there are two things you can try.
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_3200f#DriversAndSoftware
Go to that site, and download + install the windows 7 drivers, if they don't work you can use the windows Vista 64 bit drivers. Vista drivers and 7 drivers operate very similarly, so if the regular 7 drivers do not work, once again find where it says Vista x64.
SOURCE: any chance of a driver for Epson Perfection 1200
The scanner is too old for epson to make a new driver. Its not cost effective.
thanks adi
SOURCE: Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
SOURCE: BenQ Scanner 5000benq flatbed scanner 22 driver
ive go a very old flat bed scanner and the drver cd broken....help
What kind of error do you get?
