Question about Panasonic KX-T7630 Corded Phone
All phones not ringing
When receiving an incoming call only the reception phone is ringing not the extensions. The extensions ring on an internal intercom call fine but I need them to ring on external as well. Please help as this is a real issue.
Thanks
SOURCE: When a second call comes to reception, my phone rings
dial out of the hunt group on the 2nd phone:
TO LOG OUT OF THE HUNT GROUP:
* 7360 *
TO LOG INTO THE HUNT GROUP:
* 7361 *
Posted on Jul 17, 2008
cnavarro
  • 2460 Answers
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
Posted on Sep 04, 2008
cnavarro
  • 2460 Answers
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Posted on Sep 09, 2008
SOURCE: Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Posted on Jan 02, 2009
SOURCE: I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Posted on Jun 24, 2009
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Incoming calls sound only on reception desk.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Nov 02, 2009 | NorStar T7316E Corded Phone
Old reception phone now regular office - reprogram
Programming is done on M7310, M7324 and T7316 sets.
The display should say line 001: appear& ring
press the Chng key till it says appear only
The display should say line 002: appear &ring
Oct 26, 2009 | NorStar M7324 Telephone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
My phone, a meridian M7208, does not ring incoming calls
following a power failure, the only phone that rings is the one in reception. light still flashes but no ringing from any other phones
Feb 16, 2009 | Nortel Meridian M7208 Corded Phone
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
43 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
