Trouble starting computer
When i start computer it wont go to windows.It says to reinstall file 32 and i dont have a cd to reinstall this file.Im currently using a friends computer.How can i fix my own?It wont even let me on the net.
  • 3 Answers
If alternate configuration does not work. what is error mesage if any?
check to see if recovery partition and use, (caution this will erase all files)
if not find recovery disc and when you get to reinstall. ONLy use the repair function first.if this does not work, put in cd again this time go to instal part but only reapir again then, repair this will preserve your data. the only thing requriered is you product key.
if this does not work you will have to do a full install and will wpe your data.
Posted on Aug 18, 2012
  • 12,061 Answers
OK well ya have to "get" the file(s) and reinstall them where needed... maybe ya install files are on the hard drive ? check.. else use another PC and Down Load what ya need... OR Try starting in "Safe Mode" press F8 at boot up time.. and select "Last Know Good Configuration" & see if that helps... else ya just gonna have to get a CD/DVD from somewhere and use that to fix.
Here is a link to help...
http://www.michaelstevenstech.com/XPrepairinstall.htm
GL
Posted on Jul 29, 2008
My PC wont to start .its says to reinstall windows root system 32 hall.dll
go here to download it on another computer>> http://www.dll-files.com/dllindex/dll-files.shtml?hal
unzip the file onto a USB zip drive than go plug that into your computer and install it. should be pretty simple if it doesn't work try going here and reading up for other possible solutions >> http://social.microsoft.com/forums/en-US/tabspace/thread/b82154ee-6dfd-4ed6-8450-cb22cce444f5
Nov 14, 2010 | Computers & Internet
I have an hp 511w that displays the message file missing or corrupted. WINDOWSSYSTEM32CONFIGSYSTEM that is the last screen i can access. anything i try to do (like push f8 or f1) doesnt work. i cannot...
You most definately have to restore windows.That system 32 config file is part of the boot process.Yours got corrupted .I take it your computer is out of warranty.If its not try calling hp and maybe they might send you recovery cd.
Good luck
Nov 12, 2009 | Computers & Internet
Winodws sytem 32 file not found
Have you got an Anti-Virus program installed , do you have an Anti-Spyware program installed
If not when you get this machine running again go to www.filehippo.com and download Avast and Spyware Blaster
To get it running go to
http://support.microsoft.com/kb/307545
Jul 01, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
Error message when starting up: <Windowsroot>\system 32\hal.dll. Please reinstall a copy of the above file.
This issue happens if boot files are corrupted .. you need to have the Operating System Cd to resolve this problem . Considering you have windows xp you need to have the installation cd for windows xp .
you need to use bootcfg command to resolve the issue.
Go to bios and change the boot sequence to boot from the cd, if you are not able to boot from the cd. and then boot using windows xp cd .
Then push R to go to recovery console and use the below command
Boot to Recovery Console and rebuild the BOOT.INI file with the BOOTCFG /REBUILD
command.
May 09, 2009 | Microsoft Windows XP Media Center Edition...
Start up
what a pity! if you Windows is really just had a corrupt system file that caused it, try boot with this CD to recover bad sectors: "HDD Regenerator 1.51". This is also available in Hiren's BootCD.
By the way, what Antivirus you are using on the laptop? The cause of this may due to a Virus wrote a startup system file entry into the registry but your Antivirus picked up the file and removed it however not the action. That's why a file is "missing" upon reboot.
What you can do lastly is to take the harddrive out, put it into a external harddrive case, backup all your data from another PC, and reinstall Windows on the laptop.
Apr 12, 2009 | Toshiba Tecra A2 Notebook
Windows wont start up says needs system 32 hal.dll.
You should be able to do a repair as long as you have the windows installation disk.
You also might be able to take the computer back in time if it will boot to safe mode (or last good boot). Start tapping on F8 after you turn it on to get to the boot preference screen, then select Safe Mode.
Mar 14, 2009 | ASUS Eee PC 1000H Laptop
Windows 32 file is missing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0mm 5.4pt 0mm 5.4pt; mso-para-margin:0mm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows 32 file is a system file this one along with others if faulty or corrupted will stop windows working
The easiest way in the long term is to.
Boot from Windows CD and after all files are loaded. Windows will ask you what you want to do. Install, Repair etc. Choose repair and follow instruction from there Windows will remove some files and reinstall in repair mode. You will not lose any files, during this process.
The reason I choose this method is because you can spend some hours trying to fix not starting problems and not succeed while a reboot in repair mode takes ¾ of an hour plus time to load drivers
Oct 17, 2008 | Intel D845GVSR Motherboard
Compact Presio V2000
the boot files are corrupted, you might want to reinstall your windows, or repair this through software
Aug 23, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
