Question about Canon BJ 30 InkJet Printer
Canon BJ-30 Bubble jet printer F-12 error
F-12 code error appear ona LCD while printer turn on
  • Anonymous Feb 10, 2009
    f12
    Problem Solver:
  • 4 Answers
Hi, According to my BJ-30 & BJC-70 user manual, if F12 is blinking, it is required for this Error code to get in touch with a Canon Service Centre. I had this in the past and being curious I removed the printer chassis from case the and found the problem to be a loose ribbon cable in the connector on the main board from the touch pad circut board . I also had the identical problem with my BJC-70. These printers are very reliable and compact, it seems to be a problem which I think comes about from these printers being so portable. It took me about 15 minutes to fix the problem for which I have made a small modification to hold the cable in place. Having said this, it may not necessarly be your problem but it is a starting point. Canon to my mind have not made another portable printer this good, so if you value it and can find a trustworthy technician get it fixed. If you want further info contact me here.
Regards Roger D
Posted on Jan 15, 2009
Problem draiver
Posted on Nov 18, 2010
I am using a canon bj 200ex bubble jet printer but recently it strated to leave out strips so that i cannot read the text properly, how can i adjust it?
The BJ200 is quite an old printer. The problem you're describing is indicative of a head failure. If replacing the cartridge doesn't work, you may have a faulty head. If the cartridge includes the print-head (some do) it could be the contact strip on the cartridge cradle.
My honest advice would be to retire this printer, and buy a new one. Even the most basic model you can buy now would exceed the bj200ex in both quality and speed - and would be inexpensive to buy.
Oct 30, 2013 | Canon BJ 200EX InkJet Printer
My canon BJ 10 EX bubble jet printer wont recognise that a sheet of paper has been loaded, the out of paper light remains on. Does it have a mechanical or electronic sensor to detect paper insertion?
Yes you are right there is an electronic detection of the paper detection at the insert point. This is an optocoupler which can be checked for the failure of the detection. replace and proceed. Good day
Aug 12, 2010 | Canon Office Equipment & Supplies
Is the Canon BJ-30 a color printer?
Nope. Canon BJ-30 is not a color printer.
It is same as BJC-70 but only the color printing ability is not available in it.
BJ-30 is Black & White inkjet printer with max 360x360 dpi.
Hope this helps.
Feb 27, 2010 | Canon BJ 30 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon Bubble Jet printer won't feed paper and print properly.
    Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
    Nov 07, 2009 | Canon BJC-85 InkJet Printer
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Canon BJ - W9000 Error code: B800A
    The BJW 9000 manuel is available as a free download I have downloaded it my self but dont have it at home why not do the same
    Tony (withtrader)
    best of luck
    Feb 10, 2009 | Canon BJ-W9000 Copier
    Error message
    The manual for the BJ-30 can be found here: http://downloadlibrary.usa.canon.com/cpr/pdf/Manuals/BJ30_user_manual.pdf On page 97 (105 of 183) it indicates your error message. Unfortunately, it does not give a way to resolve the issue other than bringing the device in for repair. I then came across this page which is a bit more descriptive with the error codes. http://www.uktsupport.co.uk/canon/bj/bj30.htm F12 is aPrintHead Temperature Error. It suggests trying to install a NEW print head. if the problem continues, the printer will require service.
    Oct 17, 2006 | Canon LaserBase MF5650 All-In-One Printer
    Canon BJ 30 InkJet Printer Logo
    1,227 people viewed this question
    old marine
    old marine
