Question about Sony VAIO VGN-N130G/W Notebook
Laptop battery and AC adapter
Have a sony notebook (VGN-N130G) and I belive the battery is dead. It no longer holds a charge. Also, the AC adapter makes a weird chirping noise when it's plugged up. Could the AC be the problem or should I just replace both? Is it safe to buy a generic battery? Sony wants a lot of $$ for the battery.
    Genius:
  • 2,028 Answers
Replace the power supply first, chirping is not good, and if the supply has a low output it could be putting out just enough to run the machine and not enough to charge the battery. Starving the machine for power can damage the machine or the battery, so, you may still need a battery, but you won't know until you replace the supply. If you do need a battery, aftermarket or generic batteries are fine. I've used them and had no problems. Many times you'll find that the aftermarket batteries are made by the same company that the laptop manufacturer uses, they just don't have the label, it's this way with damn near all the laptop manufacturers.
Posted on Jul 30, 2008
Sony vaio not charging while charger plugged in
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Oct 27, 2012 | Sony VAIO VGN-NS160D/W Notebook
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
How to change hard drive on Sony VGN-N130G?
I need the model number printed on the front of your case, VGN-N130G does not exsist on the sony web support page. http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
Usually there is a cover under your laptop that is marked.
Remove 1 or 2 screws and your harddrive should just slide out.
Jul 14, 2010 | Sony VAIO VGN-N130G/W Notebook
I have a Sony Vaio CR-120E laptop. The battery on the laptop is dead, so I took it out. Can I run only the AC Adapter to power the computer? Also is there a setting within the computer to set AC Adapter...
Yes, you can start using the laptop only with AC input and there is no extra settings to configure the same. But you will be not getting any backup when the power goes.
Revert back for more assistance
Jan 18, 2010 | Sony VAIO VGN-CR120E Notebook
When first setting up the laptop do we need to charge the battery completely even when using power adaptor?This was sent overseases and was in storeage for awhile now it will not power on at all.
No, it should start right away, even with a dead battery.
Try removing the battery and just using the power adapter to start the computer.
If that doesn't work, let me know.
Feb 27, 2009 | Sony VAIO VGN-N130G/W Notebook
Schematics for Sony VGN-N130G
find out what kind of motherboard you have and google the schematics. i did this before and it worked
Aug 04, 2008 | Sony VAIO VGN-N130G/W Notebook
Noise coming from AC adapter
There is a possibility that the power managment sestem in the computer has malfunctioned and is back feeding and burning up the supplies. You will need to take this in for a professional diagnostic to find out if you have a back feed problem. A back feed problem is rare, but not unheard of.
Jul 16, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Sony vaio Adopter is beeps when i connect to power supply
I think ur adapter have some problem.Better to change ur laptop adapter and check it.whether it give same problem.Then please contact nearest service center.
Thanks
Feb 26, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-N130G/W Notebook Logo
302 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
