SOURCE: where can i get Pogo Radio YourWay LX Replacement
You are going to have to modify the battery compartment since Pogo is no longer in business. You will need a Dremel to cut the back plane of the battery compartment out. The back plain is the plastic piece that the separate the circuit and battery compartment. When you insert the battery it is inserted until it stop against the back plain. You will need to remove the back cover to cut the plain out. Once this is done just take teh old battery to a battery store for a replacement. the voltage should be 3.7 volts, and as close to the MA as possible. Also make sure that the new battery has the right connector or otherwise you will have to reuse the connector from the old battery buy cutting the wires as close to the old battery as possible and resoldering to the new battery. good luck
Do you have the manual for the POGO DR-A1000?
