This happens to all xbox 360 owners,there is an easy way to get it fixed at home with out having it repaired. Get 2 Q-tips stick it on the back of the xbox where all the holes are. The Q-tips block the fans,this causes to make the xbox hot. Wait a few minutes and you'll see two red rings. When you see them take out the Q-tips and turn off the console and then turn it back on. It will work. If not then try to shake it or hit it lightly on the side.
It sounds like a Red Ring of Death, which basically means there's something wrong with the unit. There are many reasons why you can get an RRoD, but it's usually hardware related. You can find out more information on RRoD here and and what to do from Xbox Support here. You can also contact Xbox support at (800) 469-9269. Even if your 360 is out of warrant they may still cover repairs for red ring errors.
Hope this helps
Ray
It's called the ring of death
does it look like this?
there is a fix for it, I looked up a website for you, how to fix it.
http://www.squidoo.com/xbox-troubleshooting-red-ring-of-death-fix
I hope this helps you my fellow gamer.
This is considered the "Red Ring of Death". If your Xbox is under warranty call Microsoft and see what options are available to you to get that repaired. Even if it is not under warranty, still call Xbox. They can give you a list of local repair facilities. You can also go to their support website at: http://downloadcenter.samsung.com/content/UM/200905/20090526153814125/CMS_-_S5230_UM_OPEN_Eng_FINAL_Rev.1.1_090420.pdf
