Website is detecting visitors IP and showing up in right corner. no need to worry.. i dont have any malware or virus in my pc but it shows my IP too. so chill and keep surfing.
Yes, you will lose it since it was part of the dialup account. Also all the data and addresses stored on that account will be lost . Set yourself a free internet email (one for which you need only a browser to access) and notify everyone that you changed the mail address
This is clearly a problem with the memory. You can try two things:
1) Remove and reseat the memory sticks (with the unit unplugged)
2) Swap the boards around. Windows is not very tolerant of errors in the lower portion of memory. Swapping around the boards will change the relationship of physical memory addresses to virtual addresses. At the very least, the memory swap may help to determine which memory stick is defective.
hi I dont work on Sharp machines but this may help
If a PC or network is running DHCP it means the IP addresses are on a short lease and are called Dynamic IP addresses. If DHCP is turned off then your PC's are running Static IP addresses which means that they will not change. Ok...if you are running dynamic IP addresses your scan to PC destination will have to be the host name of your PC and not an IP address eg james. to find out, do the following start,contol panel,system,computer name.
The IP address that you have is an automatic IP address the Windows generates. It basically means your computer is not getting an IP address from the router (DHCP). You should try powering everything off. Then, in this order, power on your modem, wait 30 seconds, then, power on your router, wait 30 seconds, then power on your computers...This should fix the problem since one computer is working already.
