Question about Sanyo DP32746 32 in. LCD Television
32' sanyo HD
I when i turn it on it flickers for a second or two then it blacks out but the power is still on
  • 71 Answers
Use a spike guard next time. now run the service center,
Posted on Mar 05, 2009
How do I fix my LCD TV's ability to display picture?
it may be from inventor board that make light for screen.
Apr 18, 2016 | Sceptre X322bv-hd 32" 720p Hd Lcd...
Plasma tv video
Could be the power supply inside the TV is bad. Check with your local authorized Samsung repair center. DON'T try to fix it yourself.
Dec 03, 2013 | PN50C675 Samsung Factory Refurbished...
Coby HD LCD TV Blinking and Flickers ?
It sounds that the problem is with its back-light inverter baord itself
May 28, 2013 | Coby TFTV3225 32 in. LCD TV
Sanyo dp42848 with soud no pic
There is sone short circuted components at its main board. Contact a technician. This is not a user repairable work.
Apr 27, 2013 | Televison & Video
Hdmi shows hd not turned on
Check the input is HD and if using a box unplug for a while and power back---box will reboot etc.
HDMI can be touchy and does not like being disconnected or connected if unit is powered or on.
If the set has a component input for HD try that also instead of the HDMI.
Nov 07, 2012 | Sanyo HT32744 32" TV
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
My 42" hd Sanyo flat
chances are your backlight inverter circuit has failed, repaired one a few months back with the same problem. To verify this, take the tv in a dark room. plug it in and take a bright\ flash light and shine it on the screen. turn the set on, you should see either the screen saver or video from your source. If this is the case, your inverter is at fault. Depending on your model, your backlight inverter is built onto your power supply board so you will have to replace the power supply/inverter board. Not hard to do, you can do it yourself with care.
Sep 23, 2011 | Sanyo 42 in. LCD TV
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Dec 07, 2009 | Televison & Video
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Sanyo DP32746 32 in. LCD Television Logo
96 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
