Question about Sharp Microwave Ovens
What is needed to install the Sharp R1880LS? Is a bracket needed? Thank you, Jill
  • Sharp Master
  • 9,098 Answers
If you don't have your installation instructions, you can download them here. You will need the free Adobe Reader to view or print this document.
It will tell you what parts are needed. The best place to order Sharp parts is Tritronics.
Posted on Aug 03, 2008
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
I own a 1993 (but very seldom used) Sharp R-1830 Over-the-Range Microwave. Worked perfectly until a total death yestereve. The oven light went out last week and now the control panel neither lights or...
There's need to remove the oven from the wall to check and replace the fuse.
Just see the video here to show you how to remove the grille and controller assembly.
The fuse is located between the door switches.
If the fuse blows again as soon as you press "Start" to begin cooking, then you likely have a shorted high voltage capacitor.
Let me know if you need further assistance.
You can find helpful exploded views and order parts at the Sears Parts Direct Web site.
Jan 08, 2014 | Sharp Microwave Ovens
How to uninstall a sharp 1502 microwave. We've removed two bolts on top through the cabinet and four screws in back under the mounting bracket. The microwave is still stuck in the back on the left.
We have the owner's manual at our site here, and it contains the installation instructions.
Dec 26, 2010 | Sharp R-1502 Microwave Oven
We're trying to remove our sharp R-1420B microwave oven off the wall. We're having absolutely no luck. How do we get this off the wall?
I just removed our Sharp R-1420B microwave. Unplug the microwave. Start by removing the two bolts from the top cabinet (one left and one right). Remove the decorative screws (one left and one right) from the bottom support bracket. I used a plastic bucket sitting on the range as support under the microwave (you may need a couple different sizes). Once the bucket is in place, pull down on the attachment brackets where the decorative bolts were located near the bottom. I used a vise grip to attach and pull them down, and they came down fairly easy. By doing this, the top of the microwave should become detached from the wall. Once you allow the microwave to tilt down far enough (you may need to move the bucket or use a shorter one), you should be able to lift the bottom of the unit off the lower support bracket. Now you can just pull it out from the wall.
May 16, 2010 | Microwave Ovens
How to get sharp r-1440 disassembled from under
Probably don't need this anymore, but there is another post, which we added to. Hope you had success.
Be sure to unplug first.
It is mounted on a steel bracket which the micro was tiled into place on. The bracket covers the entire area of the wall where the micro sits.
Basically, two screws in the bottom of the overhead cabinet, and two more screws located in the venting area of the microwave (under). Take the vent filter covers off each side, and remove one screw on each side carefully. If you take the fan cover off in the top front, you can see the steel support on the left.
Two people: The micro is then lifted up and off the support slightly, and then tilt forward to remove.
Jul 15, 2009 | Sharp Microwave Ovens
Remove Sharp R-1510 from under cabinet bracket
It normally sits in. So puch up to release it.
Apr 12, 2009 | Sharp R-1510 Microwave Oven
Mounting brackets for Sharp R-1872
Did it have the installation instructions? That will list the part numbers you need.
If not, the original part number for the installation instructions was TINSEB371MRR0, which was replaced by TINSEB141MRR0. (both end in zero, not "oh")
You can get the latter via Encompass (formerly Tritronics, the best place to get Sharp parts).
Or you can call them toll-free at 866-779-5835, which will get better results. They should also be able to tell you the parts you'd need to install it.
Jan 11, 2009 | Sharp R-1872 Convection/Microwave Oven
Limited space for over the range microwave
You can call Sharp and ask them what current models if any will be drop-in replacements,either using the same mounting hardware or at least the same space.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Oct 19, 2008 | Sharp R-1460 Microwave Oven
There's only one main power fuse, and it's located behind the control board assembly. Once you remove the board, you should see the fuse mounted in it's own clip. They're sometimes mounted on the white plastic bracket housing the door switches.
Jul 09, 2008 | Sharp R-1850A Convection/Microwave Oven
Removing a Sharp Carosel R 1440 over the stove microwave
you should be able to do this yourself. Do you have an outlet to plug this into, or will you need to hard wire it into your apartment/house wiring/. If the former, then you should be okay. You will need a bracket/plate to mount the microwave to.
May 26, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
