Question about Cuisinart SS Grind Central, removable bowl w/ cover Grinder
I can't get the removalable bowl off the grinder. I think the blades are stuck.
  • marlasaul Aug 06, 2008
    I can't figure out how to get the bowl off of the grinder so I can clean it.
  • 24 Answers
This seems to be a widespread problem on units manufactured in 2007 and later.
Unplug the unit from the AC outlet. Remove the six screws that hold the lower plastic cover on the motor base (four screws are hidden under the adhesive rubber footpads). This exposes the lower end of the motor shaft, which has a slot in it. By inserting a flat blade screwdriver into the slot and holding the cutting blades with a rag or a wad of paper towel to avoid cutting one's fingers, it is possible to twist the shaft back and forth about 90 degrees. You may need another person to help, because one needs to perform this twisting action while pulling the motor base away from the grinding cup and blade assembly.
Once you get the @&%$#! thing apart, reassemble the motor base. (With the slotted motor shaft, why didn't the designers simply put a hole in the plastic base so one could stick a screwdriver in without disassembling it?) Plug it into the wall outlet and use a small object like a toothpick or matchstick to activate the recessed motor switch so you can spin the motor without the grinding cup in place. Use the blunt edge of a small snap-blade utility knife as a scraper to gently scrape the plastic pin of the motor shaft as it spins, much as one would work a wood turning lathe. Periodically check the fit of the brass hub of the grinding cup on the plastic pin. Continue to shave the pin until the grinding cup slips onto and off the pin with no resistance. Take care to machine the pin uniformly from top to bottom; avoid making grooves.
Why this mechanism worked properly when my grinder was new about 18 months ago and suddenly decided to get stuck this week is a bit of a mystery. The unit in question has been used since it was purchased exclusively to grind flax seed, but the ill-fitting pin normally doesn't come into contact with foods, anyway. There was no obvious evidence of swelling of the plastic due to heat from the motor or oils from seeds. Since the blade and hub are free to travel up and down on the plastic motor shaft pin a bit, I suspect that on occasion the blade doesn't settle properly and the clutch doesn't engage, allowing the pin to spin in the brass bushing until it starts melting, and then the hub settles so that the clutch is fully engaged. This may happen in a matter of just a couple of seconds of operation. Once that happens, the pin conforms to the microscopic grooves inside the brass bushing, allowing it to still turn slightly relative to the motor shaft, but locking it on so that it can't come apart. If Cuisinart had made the pin more tapered and the hole in the brass bushing to match, much like a Jacobs taper on an industrial drill press spindle, this would be much less of a problem.
BOTTOM LINE: Before loading the grinding cup and starting the grinder, push the blade hub down with your finger to make sure the clutch is fully engaged.
Posted on Dec 09, 2009
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
SHOW ME HOW TO REMOVE THE BOWL
IF your bowl is stuck, then gently pry it with a thin flat edge screwdriver. If the bow is separated from the base then you will have to glue it. Watch the youtube video to see how she removes a bowl that is not damaged. http://youtu.be/OMrhdg7Jfa8
Nov 06, 2013 | Cuisinart SS Grind Central, removable bowl...
My saniflo just hums but won't drain how do I unblock it if that is my problem
Rick: It sounds like the grinder is bound up in the unit. Hair can get wrapped around the grinder blade and freeze it up. Take the unit out and remove the grinder blade and see if that fixes the problem. New grinder blades are available from Saniflow USA.
Nov 23, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My Cuisinart DCG-12BC coffee grinder, the bowl is stuck on the motor base. It works and turns, but it will not come apart to be able to clean it. Please advise.
.... mine stuck after "first" use ... solution ... took it back to the store, got a refund, bought a Mr. Coffee Model IDS77 which was $11. cheaper, has automatic grind settings and a superior bowl arrangement... Then I put Cuisinart on my list of DO NOT BUY ... anything can have problems, but something obviously this chronic should be handled better by the manufacturer ... it should have been taken off the market and fixed ...
Aug 27, 2011 | Cuisinart DCG-12BC Electric Blades Grinder
I just want to know how to clean it after use - it is a coffee grinder, SmartGrind
How to Clean SmartGrind Blade Coffee Grinder - White
1. Always unplug the unit before cleaning. Wash the lid in warm, soapy water - not in a dishwasher.
Wipe the grinding bowl, base, and other parts with a slightly damp cloth or sponge. Take special care
around the blades; they are sharp! Dry parts thoroughly. Do not immerse grinding bowl, base or plug
in liquid or under running water.
2. Never use harsh detergents or abrasive cleansers or scouring pads to clean any
part.
3. To remove residue or aromas left behind by nuts, grind one tablespoon of baking
soda in the bowl then wipe thoroughly.
4. Use the built-in cord wrap on the underside of the unit to store the cord
Nov 04, 2010 | Black & Decker Black and Decker CBG5...
Rock stuck in grinder. just spinning noise when it
It is not a healty sound,seems either the gear cogs slipped or the plastic base that holds the lower blade of the grinder is broken.
Jan 02, 2010 | Saeco Talea Giro Espresso Maker -...
Stuck Grinder Bowl
Apr 14, 2008 | Cuisinart SS Grind Central, removable bowl...
Cup for grinder
This happened to mine this morning. I was so frustrated because the reason I bought this was because of the removeable bowl. My bf got it off but he broke off a piece of plastic (he is pretty sure the piece of plastic was on the bowl part).
I put it back on and it kind still worked- I think I will just need to get a replacement bowl now - but it was hard to get off again.
When I tried to get it off the second time, I moved it into the "unlocked" postion and then manipulated the the blade part while pulling and it came off - but of course mine was broken already.
There appears to be two areas where it locks - on the base and a part on the bowl. I think somehow they get out of synch.
The problem is not with the base I think but with the bowl.
Although, now that it is "sorta" broken - I can't remember what parts were supposed to be loose before and which ones were not. The blade part of the bowl is very loose now. My boyfriend is pretty sure the plastic broke off the bowl part so I am going to get another bowl. I hope that solves my problem!
Feb 04, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Cusinart grind central DCG-12BC
Jan 19, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Stainless Steel bowl is stuck to the body and is not removable. HELP!!!
Same problem. I even removed the housing and used a screw driver on the slot on the end of the motor shaft, and could twist the blade slightly hold the shaft from turning, but it still would not come off. I even used pliers to try and pull the blade off. Still won't budge.
Jan 15, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Cuisinart SS Grind Central, removable bowl w/ cover Grinder Logo
499 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
