i20 error code means: Water is not pumped off and could be:
Fault with discharge pump
Discharge pump deenergized (faulty wiring or no activation by electronics)
Obstruction/blocking (filters in the appliance, discharge opening in discharge trough, discharge pump, discharge hose, siphon, cover plug at siphon connection not removed during first commissioning)
Discharge hose bent or connection height above 100cm
Ball valve in discharge trough glued / blocked (discharge pump does not aerate)
or water level inside appliance is not detected and than
could be:
follow the pipe iced the machiene and there is a sprung clip like a jubilee clip holding it on ..... you'll need a pair of pliers to squeeze it together
The econo cycle is the shortest cycle on the dish washer. You have a mainboard issue with it or something. Most cycles on newer dishwashers take 2 hours.
You have a hose discharge problem,
If you are connected to a sink outlet , undo it & make sure it`s clear , check your out hose for kinks, make sure fillter is clear, try a rince to see if it clears your suds.
all the best.
Elimination Of Problems From Most To Least Likely:
1. Connection from discharge hose to drain pipe is blocked/corroded. a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting. b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver. c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection. a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle. b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c). c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line. 3. Pump has failed internally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely require removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
3. Pump has failedinternally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
