Question about Linksys Wireless-N WRT150N Router
Ethernet lights number two is off..i reboot everything is it wont work
    Genius:
  • 1,689 Answers
If after pressing the reset button on the unit for 20+ seconds and still no light to where your PC is connected, you may need to cosult Linksys for its warranty (replacement) because there is a clear issue with one of the LAN port of the unit.
here is their toll free tech support number
1800-326-7114
Posted on Jul 29, 2008
Ibm lenovo t60 ethernet not working
Did you reboot the machine? Did you reboot the wireless device? Try this procedure: http://compnetworking.about.com/cs/windowsnetworkin1/ht/renewipaddrwxp.htm
Dec 12, 2012 | Lenovo Thinkpad T60 Notebook
Does'nt work with window 7 need help
do a manual configuration :- made a hard wired connection with router - make sure Ethernet light is on and open IE type on address bar 192.168.2.1 (just these number on explorer even you are not online) you will get login for router setup page (leave blank and hit submit ) do a soft reset - if u have a cable connection ISP then click on mac clone on the left side and click on clone - once did the clone and the router is rebooted , unplug power cable for router and modem (if u have cable modem like arris ,rca , unplug the batteries from the bottom of modem so all the lights go off) and once all goes off then plug it back - everything will be fine - for dynamic connection like att ,verizon - just a reset will do all.
Oct 01, 2010 | Belkin (F5D7230-4) Router (587009)
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Ethernet cable 'splitter': Works on AT@T 'light' modem but not on cable modem. Are splitters speed sensitive
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
Oct 25, 2009 | Linksys computers10: EtherFast Cable / DSL...
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the...
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Sep 29, 2009 | HP Pavilion N5415 Notebook
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Jul 24, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
Jun 01, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Linksys Wireless-N WRT150N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
