Blinking blue light
Hi There, the blue light blinks but doesn't turn on properly, the machine won't work. Should I open it up and connect directly to the disc?
thanks
  • 5 more comments
  • edgar1813 Aug 01, 2008
    Hey, I have a WD 500GB, the converter has a green light that works, but starts blinking as soon as I plug it to the unit. Then the circle light starts blinking and doesn't turn on, nor I see it in the computer. I think I need to open the HD and connect to the computer directly to check, although I'm not sure how to do that...
    thanks
  • Anonymous Dec 16, 2008
    it sucks
  • Finwealth Feb 04, 2009
    Same problem, does anyone know how to fix this?
  • Anonymous Feb 06, 2009
    just blinks but mac doesn't recognize it. Has recognized it before
  • Anonymous Feb 14, 2009
    worked for about a week, then stopped working, and the light began blinking. Now Windows doesnt recognize it.
  • coach894 Mar 02, 2009
    My lacie 500gb quadra external hard drive light is flashing blue? How do I get it to work and show icon on desktop?
  • oramos900 Mar 29, 2009
    my WD 640Gig external won't pop up on my computer, and starts blinking when I plug it in. should I try ot crack it open? if so, how should I go about it as I tried looking for a spot on it that would make it easy to pop open but I haven't found anything.
    Champion:
  • 208 Answers
The only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Posted on Aug 01, 2008
2 Suggested Answers
SOURCE: hard drives
sounds like the hard drive
you may need a new one there
Posted on Aug 23, 2008
PS3 3D TV Display Doesn't turn on 2 red blinking lights
HI, in this video you will find how to fix your Sony 3D Display
https://www.youtube.com/watch?v=OdPGSZnTIPw
Dec 02, 2012 | Sony PlayStation Televison & Video
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
1999 2door blazer installed new fuel pump 60psi when tested won't start dump gas in intake starts and shuts off ??????
Sounds like your injectors aren't opening if it holds that pressure. Get a "noid light" at parts store that fits your injector harness connection (just a few bucks). Just pull connector off injector and plug in noid light. When you crank engine, the light should blink rapidly. Try all of them, or at least one on each bank (side).
If light doesn't blink, then check your injector electrical circuit. Power to them is fed through your ignition switch, and the ecm grounds that particular injector at proper time to make injector work.
Oct 31, 2011 | 1999 Chevrolet Blazer
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
HP 1320 will not print
hi..
what about the ink levels...open the backdoor of the machine and check for any obstacle....disconnect all the cables..press and hold down the power button for 30 sec..reconnect all cables..try again...try connecting the machine directly to the walljack.
Nov 25, 2008 | HP LaserJet 1320 Printer
Hard drives
Aug 23, 2008 | Computers & Internet
Computers & Internet Logo
4,863 people viewed this question
David Payne
David Payne
