Question about Sony KDSR50XBR1 50" Projection HDTV
New HDTV bulb
I bought a 50" KDSR50XBR1 Sony projection TV on 08/09/2006 and was told by the sales person to be sure to order a new bulb before the two years is up and that I could do this online.
Where do I go to do this?
Thank you
Curts
  • CGTeel Oct 02, 2008
    They said I get one free bulb with the purchase of the TV.
I have just bought a second hand Sony 50 inch Projection & the owner from new (paid 1200 Quid) assures me he has never replaced the bulb in 6 years. Don't pay 190 Pounds plus, if you can loosen 2 nuts you can get an Osram bulb alone (not mounted) for 32 Pounds 55 Dollars delivered if you search well on E Bay
Posted on May 19, 2012
  • 23 Answers
Before what 2 years is up? Lamps are not covered by any kind of Sony warranty...
The cost of lamps is solely on you...
Posted on Oct 01, 2008
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by...
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 05, 2010 | Sony KDSR50XBR1 50" Projection HDTV
My Sony KDS-R50XBR1 has green hues that don't seem to respond to color adjustment in the menu.
It is you Optical Block/OB. sony is offering an exchange/deal for owners of 50 and 60" xbr1. I have contacted them and they are going to send me a new TV at an awesome price. This is do to the class action law suit. optical blocks are very expensive. The tv itself is not woth the investment.
Mar 06, 2010 | Sony KDSR50XBR1 50" Projection HDTV
Standby light flashes 3 times, tv wont turn on
you need a new bulb look on the back of you tv get serial number and model number call manufacture they will be able to tell you how much you bulb will be and if you want them to replace it you have to fax your reciept and must be with warranty period and they will ship you another on and you have to return blown out one. if you are outside warranty they will tell you how much bulb is an offer you an extended warranty.
Nov 04, 2009 | Sony KDSR50XBR1 50" Projection HDTV
I have a sony kdsr50xbr1 screen turns off after 15 min, there is still sound but the screen is essentially blank. Sometimes there are bars on the side of the screen for a second. The the status light...
Hi!
Please try disconnecting all the cables from the TV then reconnecting them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then the projection lamp needs to be replaced.
Aug 27, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50 - TV comes on then goes to a black screen - sound is fine. In the 2 or 3 mins of TV visual time, the color looks a bit off - lacking red - could this be a bulb problem? Bulb does not look...
Hi
Its symptom of weak lamp so TV needs new lamp.
Lamp replacement procedure is written in user manual and lamp part number is as follows..
F93087600 Lamp Block XL-5100
Available in Sony Accessories Store, please buy Sony Original Lamp for TV safety.
Jun 26, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Is your TV still under warranty? If it is, then you should send it back and let them fix it. If you do it yourself, you might void the warranty.
Jan 29, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
