Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
Whispaire - Fan stopped working
Hello - My Whispaire was running the other night (light and fan) when the fan just stopped running. The lights still work. I checked the wiring per instructions but still didn't do it. Any suggestions?
russell.dowson@starwoodhotels.com
  • Psycha Oct 27, 2008
    I have the same problem here. My lights still work on my 6500 but the fan just stopped. if this is a fan motor problem, Can I replace the fan motor myself? Is this a common problem that can only be resolved with a complete replacement of unit? Anyone help please?
There are two small plastice yellow pieces side top and bottom of rotor sticking out from the rotor i just purchased should these be removed prior to operation
Posted on Apr 06, 2010
  • 38 Answers
You would definetly be able to replace the motor yourself, if your a handy person.
1. You must take off the blade before starting which is only held on by pressure and a mini little metal clip at the tip of shaft.
2. Motor bracket is held on by 4 star/phillips headed screws, two are located under the metal plate the retains all the wires on the right side, and two located on the left side of motor housing.
3. The motor is wired with a plastic connector (plug in plug out). Once motor bracket has been unscrewed and removed there is 4 star/phillips screws holding the motor on the bracket.
Restart proceedure to install the new motor. Part #K7448-000
Posted on Nov 06, 2008
Fan does not stop running on my 92 VW cabriolet
Take a test light and disconnect you negative lead on your battery. Put one end of the test light on the battery negative and the other end on the negative terminal. If you have a light on the test light then you have a draw. Leave the key off, shut all doors and disconnect your hood light.
Start pulling fuses until the light goes out that will tell you what circuit your draw is on. As for the fan, sounds like someone hard wired the fan to power. Needs to be fixed to OEM
Jul 09, 2012 | Volkswagen Cabriolet Cars & Trucks
I installed the Nutone vent fan light combo with night light and I want to put the fan and light (not night light) on one switch, and not use the night light at all, is this possible? Thank you.
yes there should be 3 wires coming from light one for light one for fan and one for night light just dont hook up night light wire should work fine tape or cape the wire you dont want to use. good luck
Aug 05, 2011 | Broan-NuTone N-8663RP Combination Light...
Blank screen although power light on and fan running.
Please force shut down the unit if it still is on. Then, press the power button and see if it starts up.
If that doesn't work, then please disconnect everything from the unit (Battery and A/C) and Reseat the RAM and recheck.
May 22, 2010 | Acer TravelMate 2300 Notebook
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Nutone range hood fan motor quit
You can remove it and bench test it by applying 120 volts to the fan leads. Do you know how to do this -- it can be dangerous if not done properly.
You can also use a voltmeter to measure resistance and check continuity of the motor coils.
May 07, 2009 | Broan-NuTone Intermediate Whispaire ...
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
Hello jluiken,
The motor in the fan is going bad. Unfortunately it will not be cost effective to repair the item as you will be doing an overhaul on the main component. It would be cheaper for you to just purchase a new one. If you leave the fan on for a long period of time you will see that it will become hotter and hotter, which could be a fire hazard so please be careful. Sorry for the bad news.
If you do not mind, please rate my help, I would greatly appreciate it.Thanks
Jul 04, 2008 | Dryers
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
507 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
