Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Broken belt how to fix i have a belt - Bissell 1699 ProHeat Clear View Upright Steam Vacuum
  • seankelly08 Jul 29, 2008
    need help replacing the belt that all
    President:
  • 1,673 Answers
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Posted on Aug 10, 2008
The carpet brush stopped rotating. Is there a quick fix? It rotates by hand and does not appear to be jammed in any way.
Make sure that all plug ins are correctly attached. Remove botton plate to determine if the rubber belt is broken. Replace belt if broken
Please vote if my information is helpful or not. Recommended. Thanks UAW Local974
Jun 26, 2011 | Vacuums
Burning smell. i think the belt is broken. how do I fix it?
Turn the power head over and you will see (2) screws. Remove the screws and the top cover will come off and you can get to the belt. Here is the belt you need:
Kenmore 23812 Belt
Feb 06, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
BRUSHES DO NOT TURN
It sounds like the belt came off, if it did it will be a simple fix. All you will have to do is put the belt back on and you will be good to go. If the belt is broken write down the make, model and take the belt with you a head to like walmart and see if they have a replacement. Make sure you get the right belt. If the belt is broken when you put on the new one it will seem like its too small but it will be a tight fit.
Jan 17, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
The brush doesn't spin anymore, but the belt is not broken. model DC 07; approx three years old
The belt may not be broken but after 3 years the belt will have stretched and it will not turn the brush. You should change the belt every year. Changing the belt is an inexpensive fix. I would try that first and if it doesn't do the trick I would take it to a repair shop. You can get the belt you need here:
Dyson DC07 Replacement Belts
Nov 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Help for free???? my spin brushes won't spin
I have the 7443-940, and on this one, the brushes are powered by the water coming from the water pump. If there is no water in the unit, they will not spin. I do NOT know if yours is the same way, but it's worth trying it out.
Oct 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Dyson slim upright has lost suction via the power head , floor wand is working normal
its either the power head is clogged up with debree or the belt is broken. if the belt is broken it wont wisp everything up. Take it to a shop to fix. DONT TRY TO FIX IT YOURSELF~!!! dysons are very expensive and arent made to just be taken apart
Sep 11, 2009 | Dyson Vacuums
Belt problem - when we began to vacum, we heard a sound, the rollers stopped moving
Sounds like your belt may have broken, or you have something jammed in there preventing the brush roller to spin. But most likely you're problem is a broken belt which is a simple fix that takes no time to fix
Aug 25, 2009 | Vacuums
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
205 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
