Question about Hitachi 46F510 46" Projection HDTV
Hitachi 46510 blue screen-Shuts down
I have a Hitachi 46F510. When I turn the set on, the screen is blue and you can faintly see a picture, then it shuts itself off anywhere from 30 seconds to a minute after.
I opened it up and turned it on and the green gun is not lit but the blue and red ones are.
I have read the posts on here and haven't quite found the exact problem i am having.
Do you have any suggestions?
Thanks,
Lee
  • 6slimshady9 Jul 30, 2008
    I pushed up a bit on the circuit board and turned it on and the green gun lit up. The only problem is that the set shuts off within 5 seconds now
  • 927 Answers
Good Day, 6slimshandy9;
Try and look this;
Shuts down at turn on, LEDs D955 & D956 come on & turn off asap, the rest of the LEDs on power supply will go off slowly.
Cause: Found QEA6 (2315381) and QEA7(2315391) shorted in Blue CRT PWB.
I hope this was helpful, big IRISH. Or try unplugging the blue crt socket and if it turns off. If it stays on suspect bad CRT.
Posted on Aug 11, 2008
What causes my picture to go pink all of the sudden ?
Examine the screen with set on and color set to zero--stand back and look= is screen pink to red color?
If so it may be a common issue on this Hitachi.
Usually it is an adjustment inside the set of the red screen control needing to be turned just slightly down---these are known for the red control "drifting" just slightly from time to time--answer is based on model number indicated here.
May 31, 2012 | Hitachi 46F510 46" Projection HDTV
I have Hitachi 46F510 projection tv. Problem is that the picture is getting very blury. Cant find any thing in manual for bulb replacement. Hate to throw out the tv. ...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Hitachi 46F510 46" Projection HDTV
My hitachi 46f510 rptv has a dark and blurry picture
there is a focus setting in the back pannel you need to open the back and look inside for it
Jan 06, 2011 | Hitachi 46F510 46" Projection HDTV
My hitachi 46f510 picture is dark and blurry any suggestians
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
The picture is a red color
A lot of these sets develop a problem like this--the set uses a small plastic block with 6 controls--three are focus and three are SCREENS--
most likely you just need to get at and turn the red screen control down just a little.
I can tell you how to do this from the front of the set--takes only a few minutes.
SD TECH
Jun 30, 2010 | Hitachi 46F510 46" Projection HDTV
Television will not magic focus and picture has a lot of red distortion
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 06, 2010 | Hitachi 46F510 46" Projection HDTV
I have an Hitachi 46F510. The picture is blurry. Mostly when words are on the screen (i.e. the menu).
The convergence is dead.U need a convergence kit.These websites have it.Tv Repair World.com and Shopjimmy.com.Buy the kit with ur tv model and fix it.
Sep 10, 2009 | Hitachi 46F510 46" Projection HDTV
Lights in t.v
no picture on my hitachi 46f510 46 in. rear projection t.v
May 13, 2009 | Televison & Video
My hitachi 46f510 has a blury picture. i cant even read the words on the menu..
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 11, 2009 | Hitachi 46F510 46" Projection HDTV
Hitachi 46F510 46" Projection HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
