IBM Selectric II
I found the small spring but the large spring was at the bottom of the typewriter. I guess it had popped off. How do I get it back on and how do I get the dust cover back on?
    Sergeant:
  • 329 Answers
Depends what spring it is a very common spring to break is on the motor speed torgue spring. This is just off the motor, and the machine needs it on to give you good carriage return, etc. Dust covers snap in place under the rotate cords. Be very careful these cords come off real easy and if they do, bye bye TW. Fronts snap under a front bar or rail and back snaps in a hook type unit. Very hard to tell over the internet. If you can't get reply back with a fax number or something and I can draw a picture and Fax.
Posted on Aug 01, 2008
How do I remove and replace the tab set/clear button on an IBM correcting selectric II typewriter
Yes, all the keys are snap on. Use a spring hook on top and bottom of the key and wiggle (carefully) upwards to remove. (If you don't have spring hooks, then hefty paper clips will do. Create a 90 degree or better bend on the end of the clip)
Nov 27, 2014 | IBM Correcting Selectric II
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
I cannot remove the typing element on am IBM Selectric II typewri
Once the lever is broken you must either find a way to spread the spring that holds it on apart (not easy) or take a razor blade and slide it under the black plastic cap and cut it off.
DickyO
Mar 30, 2010 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II problem
Yes, I did bring a small screwdriver from home and removed the ball. Thank you for your assistance.
Feb 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM CORRECTING SELECTRIC II TYPEWRITER
Is the key stuck in the down position? If you pull the key off you should see a spring underneath. Maybe out of position or damaged.
Aug 10, 2008 | IBM 3500 Typewriter
IBM Selectric II
It is under the right dust shield. The one that has the yellow lable.Once you get it off turn on the t.w. The hub just to the right of the center frame has a large torque spring with a small spring about an inch long that hooks on the end of that large spring, the small one has a hook on the end. If its missing or broken thats the problem. It also could need the spring that the shoe presses against cleaned. squirt some alchohol on it while its turning. get it between the white plastic shoe and the spring that rotates on the shaft. Lawrence
Jul 07, 2008 | Office Equipment & Supplies
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
63 people viewed this question
jasbo
jasbo
