Question about Garmin StreetPilot c550 GPS Receiver
Garmin C550 FM transmitter does not work
Brand new GPS, no sound from car stereo using FM transmitter, Pl. advise.
  • cdram98 Aug 03, 2008
    Accurate. C550 has a receiver, not a transmiter. Garmin support confirmed it. Thank you.
C550 does not have one
Posted on Aug 02, 2008
Turn on and word Garmin appears, then it says loading maps then it shuts down.
It sounds like you have a battery that is going bad. The StreetPilot is one of the older Gamins, and have been known to need new batteries after a few years of use. I would advise upgrading to a newer GPS.
Apr 25, 2016 | Garmin StreetPilot C550 GPS
Fm traffic quit working the two little cars are
Are you using the Car cigarette lighter adapter plug?
If so there is a fuse in the Plug, unscrew the silver tip of plug CAREFULLY it's spring loaded
check fuse.
Oct 29, 2010 | Garmin StreetPilot c550 GPS Receiver
Garmin 765T No sound for bluetooth phone
Have you tried to use a set of headphones to see if you hear anything?
Another check is to make sure FM Transmitter isnt checked
To do that Click Volume icon
bottom of screen you see FM Trans
click it
make sure there is no checkmark in Enable FM Transmitter
click back to main menu
Love my Nuvi760
Mar 29, 2010 | Garmin Nuvi 660 GPS Receiver
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
No sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Dec 20, 2008 | Garmin Nuvi 660 GPS Receiver
Using my car speakers with my Garmin Nuvi 350
No, unfortunately ther is no way to get the unit to use your car speakers. To do this, the unit would have to have an FM transmitter or be able to connect to one. It does not have this capability. Sorry.
May 20, 2008 | Garmin nuvi 350 GPS Receiver
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin GPS - suddenly has no sound - it just cut out
1. Are you sure the volume setting is all the way up?
2. Are you sure the sound isn't muted?
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CDplayers and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
4. If you don't hear sound from the headphone jack, most likely the audio output section is defective and you'll need to send it back to Garmin to be repaired.
Please let me know if I can be of further assistance to you.
- Jim
Mar 17, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
