Question about Bestec (ATX-250-12E) 250-Watt Power Supply
Schematic diagram for ATX-250-12E
Can I obtain a schematic diagram for the ATX-250-12E?
  • 1 more comment
  • farmme Aug 11, 2008
    I alsorequire a manual for a Bestec ATX 250 12E please
  • Alex Aguilar Apr 08, 2014
    You probably wont find the schematic from the manufacturers website, however there are plenty of electronics engineers and hobbyist whom inverse engineer these power supplies and either charge for the schematic or post it free for download. For instance here is the schematic I found to a similar one:http://www.smpspowersupply.com/ATX_power... If you can understand one ATX you pretty much understand them all! There are several reasons for wanting the schematic to a power supply other than just to simply repair it; For instance to mod it to take a cigarette lighter in a car as input voltage instead of plugging into a power outlet. The parts and circuits making up most ATX power supplies with the exception of the main transformer are quite cheap and can be purchased at your local Radioshack or at sites like mouser.com. I sometimes get them out of broken radios.
    Some helpful links:http://www.pavouk.org/hw/en_atxps.htmlhttp://www.smpspowersupply.com/
  • 3 Answers
I repair power supplies and various electroics, most cases it will be compacitors, or diodes which have caused it to fail!!
Posted on Jan 14, 2012
  • 3rdBaSs Jan 14, 2012
    most cases manufactors use cheap ones which some gui mes leak across the motherboard and destroy it, by allowing power spikes on lower sections of the board
    Id also like to add that you can buy an entire bag of capacitors or diodes for only a few bucks at radioshack or from mouser.com
    New Friend:
  • 3 Answers
You probably wont find the schematic from the manufacturers website, however there are plenty of electronics engineers and hobbyist whom inverse engineer these power supplies and either charge for the schematic or post it free for download. For instance here is the schematic I found to a similar one: http://www.smpspowersupply.com/ATX_power_supply_schematic.pdf. If you can understand one ATX you pretty much understand them all! There are several reasons for wanting the schematic to a power supply other than just to simply repair it; For instance to mod it to take a cigarette lighter in a car as input voltage instead of plugging into a power outlet. The parts and circuits making up most ATX power supplies with the exception of the main transformer are quite cheap and can be purchased at your local Radioshack or at sites like mouser.com. I sometimes get them out of broken radios.
Some more helpful links: http://www.pavouk.org/hw/en_atxps.html http://www.smpspowersupply.com/
Sincerely,
Alex
Posted on Apr 08, 2014
  • 5,568 Answers
Once upon a time . . . I actually repaired PC supplies but only for some oddball PCs whose makers were too stupid to buy 'off-the-shelf' supplies from others.
There is a good possibility that replacement parts to repair one of these will cost more than a new replacement supply. You just cannot compete with people who earn a couple of dollars a day assembling them.
They aren't tough to repair if you have some technical skills but it just isn't worth it.
I'm pasting part of a post below I just did for someone else who wanted to know if the board could be damaged from a failing supply-
"Since there have been some changes in available outputs and connectors even on ATX supplies, make sure you compare pictures of the supply to your own but in any case, I would recommend using a replacment rated at 350W as this will run more conservatively and not be as stressed as the 250 you now have. It won't cost a lot more and will not consume any more power but the critical components will run cooler.
Not as a recommendation, just a current example on eBay:
http://cgi.ebay.com/Mustang-Switching-Power-Supply-350W-Model-LC-B350ATX_W0QQitemZ250294363195QQcmdZViewItem?hash=item250294363195&_trkparms=72:1156|39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
 The last couple I bought were $5 each with $7 shipping charge from a US source."
Posted on Sep 19, 2008
Tip
Repairing the ATX power supply unit
<br />if you have some knowledge about electronic component, about multimeter; you can easily learn to repair the ATX PSU. here you find a simple presentation that allow you to understand the role main components with a photos.<br /><b><u>Presentation 1:</u></b><br /><br /><img src="mabroukmedal_5.JPG" /><br /><b><u>Presentation 2:</u></b><br /><b></b> <br /><br /><img src="mabroukmedal_6.JPG" /><br /><b><u>presentation 3:</u></b><br /><b></b> <br /><br /><img src="mabroukmedal_7.JPG" /><br /><b><u>here you find the schematic diagram:</u></b><br /><b></b> <br /><br /><br /><img src="mabroukmedal.GIF" /><br />the component side :<br /><br /><img src="mabroukmedal_0.GIF" /><br /><br /><img src="mabroukmedal_8.JPG" /><br /><b><u>the solder side:</u></b><br /><br /><img src="mabroukmedal_1.GIF" /><br /><b><u>Step 1:</u></b><br /><br /><img src="mabroukmedal_9.JPG" /><br /><br /><b><u>Step 2:</u></b><br /><br /><img src="mabroukmedal_11.JPG" /><br /><b><u>Step 3:</u></b><br /><b></b> <br /><b></b> <br /><br /><img src="mabroukmedal_12.JPG" />
on Nov 05, 2010 | Computers & Internet
Where can i obtain a wiring diagram
There are many places that you can obtain wiring diagrams/schematics. But- you have to be specific on what diagrms/schematics you are looking for.
If you are looking for a diagram for a car/truck, you can usually find wht you need online at specific forums. For instance: If I were looking for a wiring diagram for a Chevy Truck, I would go to a Chevy Truck Forum, etc..
Mar 06, 2015 | Cars & Trucks
How. Can I obtain a circuit diagram for a win power atx450l please.
th?id=hn.608022427297449792&w=121&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 Got here and use this datasheetarchive.com/ATX+power+supply+450+watt+circuit+diagram-datasheet.html
Feb 02, 2015 | Computers & Internet
How do I obtain Schematics and diagrams for wiring
They do not exist. Forest River may build three of the same unit side by side at the exact time and everyone of them be wired differently. I worked for a dealership that sold Forest River products exclusively and it was a real night mare at times.
What are you trying to repair or locate?
Jul 01, 2014 | Forest River 2011 Lexington GTS 235S
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
Where can I find a schematic diagram fot Enermax EG465P-VE ATX
You can't found any diagram for and specific ATX PSU
but there are some generics
Dec 01, 2012 | Computers & Internet
SCHEMATIC DIAGRAM FOR ATX250-3505
While this link will show you a schematic for a 200 Watt ATX, the one you seek should be similar.
http://www.pavouk.comp.cz/hw/en_atxps.html
Dec 29, 2011 | Astec 250W Power Supply w / External Fan...
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
3,739 people viewed this question
Top Bestec Computers & Internet Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
