Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag mav6200aww removing inner tub
I removed agitator, four screws in inner tub and can not get inner tub out. Please advise how to get inner tub out. Thanks
  • gphill Oct 05, 2008
    same probelm
  • 261 Answers
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Posted on Oct 12, 2008
2 Suggested Answers
  • 2651 Answers
SOURCE: maytag mav6200aww removing inner tub
curious as to why you would be removing hte inner tub??? possibly to repalace the main seal??? if thats the case the directions are in the newseal kit. but htere should be a starlike plastice hub seal that will need to be unscrewed that is whats holding down the tub
Posted on Nov 18, 2008
Remove maytag inner tub
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Jul 02, 2015 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
How do I remove the drum on my aav7000aww
To remove the inner tub
remove front panel
remove screws holding top to cabinet
raise top
remove hoses from tub cover
remove tub cover
remove agitator
remove bolts holding inner tub to hub. 5-6 hex head bolts
lift off inner tub
Aug 20, 2011 | Maytag Washing Machines
Suspect we have a finishing nail under the do we remove the agitator? model KAWS750LT1 I know how to get the fabric softener dispenser off
To remove the softner dispenser just grasp the outsides of it and pull up,or wiggle it side to side.It fits into the agitator by pressure and has no clips or screws.
If you dont find the nail there under the agiator the inner tub would need to to removed to see if it's in the outer tub. To remove the inner tub a special tool is needed.
Aug 20, 2011 | KitchenAid Washing Machines
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
My washer agitator spins but the tub doesn't,also see metal insid
Repair or replace is always a judgement call. Most people will be better off replacing the machine. This is a rather big job, labor wise. On a difficulty scale of 1 -10, I'd give it an 8. The metal is the inner area between the inner drum and the transmission shaft, which has corroded and started to break apart. (located under the agitator) To repair, the agitator is removed, the washer front and top are removed to allow the washer's outer tub cover to be removed. This allows the inner tub to be removed. (caution: the big nut under the agitator drive spline is a left hand thread) Then, the drain hose, water level hose, suspension rods, and electrical to the motor are all removed to allow the entire drum to be removed from the washer to allow the inner tub to be removed. The actual metal part which needs to be replaced is then easy to replace by removing a few torx head screws from the underside of the inner tub.
Oct 02, 2009 | GE Profile WPSR3120WWW
Washer has a very musty smell. Trying to raise the top to clean inner tank but it will not budge. Does the top raise on the WJSR2070B model. Do not want to break it
Yes, but I would advise to try a washer cleaner before going through all the work to dissassemble your machine.
Use the longest, hottest cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer.
You could check out for one possiblity. Others are " Washer Magic " or these: 73b1c2a.jpg fb3071a.jpg
If you still want to tackel the dissassembly: The washer front comes off by using a putty knife to push in the two retaining clips on the very top edge, where it meets the washer top. Now you will be able to access the screws which hold the top down. Of course to remove the inner tub, you still have to remove the lid switch, the agitator, agitator drive, the left hand threaded nut below that, the wire connection to the motor, the four tub retaining straps, the tub to pump hose, the four suspension rods, the tub cover and the water level hose. Then you would be able to remove the inner tub and pressure wash out the outside of the inner tub and the inside of the outer tub, if you bring the tub assemble outside. TRY THE CLEANER FIRST !!!!
Aug 16, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Elite Top Load does not spin on spin cycle
Hi, If the inner tub has dropped down, you will need to change the block that holds the tub to the shaft. Remove the agitator cap and then use a 7/16" socket to remove the bolt holding the agitator in.
Lift the agitator out and look at the block holding the inner tub. There should be two slots with two tabs sticking up inside them. You will probably see metal shaving as well.
If this is what you see, please let me know and I can direct you on further repair.
May 30, 2009 | Washing Machines
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
May 27, 2009 | Maytag LAT3600A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
1,035 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
