Question about Hoover Vacuums
Hoover Vacuum model U4471 making a very strange noise and letting of a smoke smell
  • 328 Answers
The Elite upright may need to have its drive belt checked. Check that the machine roller is still working. Then turn the vacuum off and locate the screws on the floor head by turning the machine over. If you remove a couple of screws the floor head will come off and you can check the belt. Usually old threads and hair can stop the roller bar from moving properly or may have got to the belt. Ensure that it moves freely simply by turning the roller with your hand. If it doesn't then its possible that the roller needs to be cleaned or the belt needs to be replaced. Drive belts are easy to get for most Hoover products; a smoke smell like burning rubber usually indicates the drive belt is about to give up or has simply snapped. Dont forget to rate if this solution has worked for you. Ty.
Posted on Jul 29, 2008
Hoover model 70930 vacuum. System check indicator stays red.
If the smoking at the base smells like burned rubber it's probably your belt. If it smells electrical it's probably your motor or an electrical problem.
Mar 08, 2017 | Hoover Vacuums
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Smoke coming out!
This sounds electrical. If you have had this one year or less then it should be under warranty. find your local Hoover warranty dealer at the Hoover website hoover.com
Apr 20, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac shooting sparks from motor
the motors shot some times i have fixed them if it hasn't been ran to long let me know im sure i have a motor
Dec 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Solution for "the unit is making smoke rubber belt smell how do i change the belt...hoover steam vac f7225-900
there is no belt on this model. From your description, it is definitely electrical, possibly the motor. I would have it looked at a repair shop.
Mar 15, 2009 | Hoover F7225-900 SteamVac V2 Upright...
Bunning smell.
Is it an electrical smell or a rubber type smell. If there is no smoke, it could be that the belt is slipping and causing a smell. If it is the motor, usually it would smoke, or at least quit running and making strange noises.
Jun 16, 2008 | Vacuums
Vacuums Logo
241 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
