Question about Microwave Ovens
Microwave handle replacement - Microwave Ovens
  • 6 more comments
  • mikelisa408 Aug 11, 2008
    I have the GE Advantium 120 oven also. The model # is SCA1000DCC03. It was manufactured 8/02. The door handle simply snapped off and I would like to know how to replace it.
  • Anonymous Sep 30, 2008
    This is the second time the door has snapped off. I am 70 years old and have had microwave ovens since they came out and have never had a problem with the handle. I had it replaced one time and they (GE) said they would not cover it again. I don't know what to do?
    Connie Brown, Castle Rock, Co
  • Anonymous Oct 16, 2008
    Mine just snapped off for the second time as well. GE did not pay for the first replacement, It cost me 260$. it has snapped off again just a year later.
    any help?
  • pplastri Nov 15, 2008
    I need to replace the handle. I purchased a new one, but need to know how tto install it.
  • ratruxal Nov 16, 2008
    like others, my experience is that the handle (PLASTIC ON ALL STRESS POINTS) just snapped off. SURPRISE. no metal at all in the most stressed part of the product. if i was more of the suspicious type i would say that this is not a design flaw, but an intentionally designed revenue source given their replacement policy. a great bonus for their service dealers.
    there is NO way ANYONE could look at this design and NOT see it is WRONG. Anyone know how to file a class-action? They need to fix this for everyone for free. NOW!!!
  • bernasinil Nov 21, 2008
    I have GE Advantium Model# SCA1000DB and the handle has snapped off. I purchased a replacement handle and GE says it does not come with instructions but they can schedule a technician to come out. I don't want to pay $150 to replace a plastic handle. Not to mention the whole entire unit cost $600, so to pay $150 for only the handle is crazy. How do I find instructions on how to replace my handle?
  • spark15 Nov 28, 2008
    i have had the same damn problem. I refuse to call a technician. I have a feeling it will again. The part was $25 too. Unbelievable. So i'm trying to figure out how to get to the screw on the back/inside of door and not quite getting it and need instruction, anyone?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Posted on Apr 16, 2009
I had a problem with the bottom screw boss on the handle breaking so screw was no longer held in place but managed to fix it this way:
- followed jamwillie's advice (except had to work with door in place because could not lift it off hinges on the JVM1190 model)
- used heat gun to soften up the plastic trim to lessen risk of breaking the plastic
- removed existing handle
- drilled hole deeper into broken boss, same inside diameter as boss (taking care not to drill through the handle)
- replaced bottom screw with a longer, pointed end screw which threaded into remaining plastic at location of bottom screw boss
- remounted handle
- remounted trim (needed heat gun again)
- reassembled unit
Posted on May 11, 2009
  • candew May 11, 2009
    Thanks to jamwillie for leading the way to my being able to fix the loose door handle.
    -candew-
This is a difficult thing to explain in the text forum to change. Go to Youtube or RepairClinic to see videos to make this easier for you. Whirlpool microwave door handle replacement Door Handle Replacement part WB15X10249 GE Microwave Repair
I hope this helps
Aug 01, 2014 | Frigidaire FFMV162LW Microwave Oven
Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Replacing handle on LG LMV1680WW microwave
I have never replaced a handle on a microwave. I was looking at mine. If I have to guess how to get to the screw behind the panel, I would guess the inside cover needs to be popped out. Now a day, all the covers are snapped together. Be careful not to break it.
Or look for your manual, or look it up on the web.
Good luck
Aug 29, 2009 | Microwave Ovens
GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Handle
when door is open on the edge you wil find a plastic strip .remove carefuly with flat screw driver .when removed youwill find the screws holding the handle undo screws and replace .dont 4get to replace plastic strip
Apr 23, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
2,062 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
